Results 1 to 2 of 2
Thread: Dwv lines - toilet and bathroom sink
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default Dwv lines - toilet and bathroom sink
    RE: 650 square foot seasonal cabin in Northern Michigan. Have only a septic tank at present, no field through a 4" ABS pipe. Can and if so where can I connect the shower drain, bathroom sink drain, kitchen sink drain, and laundry drain to the existing toilet (water closet) drain - before the toilet drain or after)? All will terminate into a single 4" pipe to the septic tank. The toilet is the only fixture currently connected to the septic tank. All of the other go into a dry well which has been getting saturated with the load and needs to be eliminated.
    Have heard something about other drains not being allowed on a toilet drain. Then how and where do I connect them all to the single line to the septic tank. And do Studervent's work ok? Would use one for the bathroom and another for the kitchen sinks. The shower would be vented along with the toilet up and out the roof. Is code 4" one foot on each side of the roof minimum for vents? Can a 4" ABS pipe be connected to a DWV plastic pipe (solvent welded?) Thanks.
    Because we cannot see exactly how the system is laid out and because of the extent to which you are upgrading your system you need to call a licensed plumber to come in and survey the situation and he will tell you what you need to do.
  1. heights for supply and drain lines for bathroom sink
    By Steve_P in forum Plumbing Forum Discussion & Blog
    Last Post: 09-21-2010, 01:27 PM
  2. Need help with supply lines to bathroom
    By redgreen in forum Plumbing Forum Discussion & Blog
    Last Post: 05-24-2008, 02:30 PM
  3. Moving drain lines and water lines for pedestal sink
    By ChuckVA in forum Plumbing Forum Discussion & Blog
    Last Post: 09-10-2007, 03:56 PM
  4. Bathroom Remodel - Toilet Drain Lines
    By ptl_10 in forum Remodel Forum & Blog
    Last Post: 08-11-2005, 05:57 AM
  5. Bathroom sink and toilet supply plumbing.
    By wwilson1 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-07-2005, 07:16 AM
