Thread: sink not flush with granite counter
    DIY Junior Member tikicarver's Avatar
    Feb 2010
    Tehachapi, CA
    Default sink not flush with granite counter
    Just had new granite counters installed.
    We bought a new Kohler cast iron porcelain coated sink, drop in style.
    The problem-- the edge of the sink is not flush with the counter.
    It looks like the sink is warped. The opposite corners are 1/8 off.
    For example if I press the right front corner down to touch the counter,
    the left rear corner will have an 1/8" gap with the counter.
    I checked the granite, it is level and flat.
    I'm wondering if this is normal with cast iron sinks or is the sink defective.
    They can be warped. It's not an exact science. You can try more sinks, or caulk the sink in as is, and decide which side is going to be up a little bit.
    I would op for the front edge touching the granite, and the side away from you being up.
    Or you can balance between the two sides. When it's caulked, it won't move.
    They are fired until they are red hot, so they are more likely to be a bit warped than not. Once it is caulked in place it will NOT wiggle.
    Feb 2010
    Tehachapi, CA
    Thanks for the reply. I was thinking they are probably not perfect, but I wanted to make sure since it was a special order.
    Didn't want to bring it back and wait three weeks only to find the next one is the same way or worse.
  1. Granite backsplash to granite counter help
    By coopns in forum Remodel Forum & Blog
    Last Post: 10-25-2010, 01:34 PM
  2. Composite granite sink in granite tile top
    By chris813 in forum Remodel Forum & Blog
    Last Post: 08-10-2008, 12:31 PM
  3. anchoring dishwasher to granite counter?
    By thirsytchicken in forum Remodel Forum & Blog
    Last Post: 05-13-2007, 10:04 AM
  4. Hole in granite counter top ???
    By Randyj in forum Remodel Forum & Blog
    Last Post: 01-14-2007, 12:34 PM
  5. Attach faucet directly to granite counter?
    By chrisd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-13-2006, 08:46 AM
