Results 1 to 4 of 4
Thread: Convert shower to bath - tricky space
    DIY Junior Member HousePoor's Avatar
    May 2011
    Charlotte, NC
    Default Convert shower to bath - tricky space
    Hello, I currently have a shower space that is 42"x42" stud-to-stud, and am trying to figure out how to install a bathtub in the space. Can I get a 72x42 tub and place it in the opening? The diagram of the space is attached. I found a Kohler Windward tub that has tile flanges on 4 sides, which will work where the walls will surround the tub (on 2 1/2 sides), but I wasn't sure what to do where the tub will be exposed to the room?
    You can get the tub as a drop-in, then get their tiling flange kit. Apply it where needed. If you install it properly, it should be fine, but it is less robust than having it built-in at the factory.
    May 2011
    Charlotte, NC
    Thanks - that looks like it will work. Now, can I get a 42" wide tub for an exactly 42" stud-to-stud opening and notch out the studs 1/8"? If not I will have to build a ledge and get a 36" wide tub, I suppose, which will increase the effort quite a bit it seems.
    Depends maybe more on how square and plumb the opening is. Most of the tubs are a hair under the 'nominal' dimension. It should be fairly quick to notch the studs, if required, either with a router, or a saw and chisel. SHouldn't need much, if any.
  1. Convert Slab Shower Stall to Level Floor for Steam Shower Unit
    By Saitek in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2010, 02:09 PM
  2. Replies: 1
    Last Post: 06-24-2009, 06:22 PM
  3. Convert Shower to soaker bath
    By wsmithe in forum Shower & bathtub Forum & Blog
    Last Post: 01-25-2007, 12:31 PM
  4. Bath Remodel: Tight Space Advice Needed
    By H2osun in forum Shower & bathtub Forum & Blog
    Last Post: 01-25-2007, 07:31 AM
  5. what's the smallest half-bath space?
    By old tired dad in forum Remodel Forum & Blog
    Last Post: 06-20-2006, 03:39 PM
