Nards01
I went to change a Moen cartridge and of course the 1st step is to remove the handle screw. Using a phillips screwdriver, I can turn the screw while holding the handle but it won't UNSCREW - it turns as apparently does what it's attached to. I have put pressure on the handle to help pull out the screw but no luck. I figure that I have to crack the plastic handle off??? I don't want to damage the screw neck of the cartridge that is in there so that my Moen removal tool will attach and remove it properly. Please HEEELP !!!! A 10 min job has turned into a nightmare. Thank you
