Results 1 to 6 of 6
Thread: Moen handle problem!!
    DIY Member nards01's Avatar
    Feb 2005
    Washington County, PA
    Default Moen handle problem!!
    I went to change a Moen cartridge and of course the 1st step is to remove the handle screw. Using a phillips screwdriver, I can turn the screw while holding the handle but it won't UNSCREW - it turns as apparently does what it's attached to. I have put pressure on the handle to help pull out the screw but no luck. I figure that I have to crack the plastic handle off??? I don't want to damage the screw neck of the cartridge that is in there so that my Moen removal tool will attach and remove it properly. Please HEEELP !!!! A 10 min job has turned into a nightmare. Thank you
    The handle must be broken already, so just cut it off.
    Feb 2005
    The handle isn't broken though. The screw just won't unscrew. But, if I do as you suggest what's the best way to "break" the handle off. Again, I want to be able to attach my Moen puller to the bad cartridge by screwing the puller into the "necK" of it. Isn't that what the handle is screwed into NOW??
    Jan 2008
    If the screw turns freely, it may be broken or the threads stripped. If this it the case, there is nothing other than gunk holding the the handle on.
    Dec 2007
    The handle is broken and the screw is spinning along with the center spindle of the cartridge.
    So yes bust out the handle so you can hold the spindle of the cartridge and prevent it from turning while you undo the screw to replace the handle.
    The handle IS broken internally, otherwise it would prevent the stem from turning when you twist the screw.
  1. How to remove Moen Monticello handle set
    By JeffH in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-08-2013, 05:06 PM
  2. Moen Single Handle Shower/Tub valve problem
    By short.circuit in forum Shower & bathtub Forum & Blog
    Last Post: 04-16-2009, 06:46 AM
  3. Moen 7730 leaking from under handle
    By richwag in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-16-2007, 05:28 PM
  4. Can't remove handle hub on Moen Monticello 2 handle faucet
    By jaobrien6 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-04-2007, 06:47 AM
  5. Moen Shower Handle Hub Removal
    By ededed3 in forum Shower & bathtub Forum & Blog
    Last Post: 11-27-2005, 03:57 PM
