Chuck B
sea-bee
Need to connect 3" PVC to a 3" black ABS pipe which exits an old septic system at a newly acquired cottage.
The pipe run is through a open crawl space under the cottage. Do I use SCH 30 or SCH 40 pipe. Advantages or disadvantages of either?
Also, would the 3" Black ABS pipe match SCH 30 or 40? I will of course be making my rough drain connections throughout the cabin from the PVC.
I have purchased the "Green Bottle" ABS to PVC cement. Is it true that you only primer the PVC and NOT the ABS (hearing that it dissolves ABS)?
Thanks.
Thanks.
