Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Replacing Basement Windows
  1. #16
    Jun 2009
    Canada
    Quote Originally Posted by Cookie View Post
    Wood always looks better, is a better insulator over vinyl
    Huh? Since when,
  2. #17
    Quote Originally Posted by bjferri555 View Post
    I have Simonton vinyl replacements and love them. Google them and go to their website. I believe they are the best in the industry.
    I will not buy its hopper basement window anymore. the quality is good but the glass size is much smaller than others. I bought them this month (5500 series) but found the product is not the same as the images on their web site. you will loss about 2" glass opening, I think. glass size is important for basement.
  3. #18
    Yes, glass size is important. I think I'm going to remove the old windows and try to use the existing buck, if it's sound and solid. (but, keep some treated 2x4 on hand in case I have to build a new buck)
    2 more questions:
    -New construction windows (with the nailing fin/flange) if I screw through the flange into the buck, is that enough to hold the windows? Or do I still need to shim and screw through the shims?
    -How do I weatherproof the whole thing? Liquid flashing on the existing buck? or cut/rolled flashing? I've seen people use tar paper, etc. is this needed?
    THanks...
  4. #19
    DIY Member Agu's Avatar
    May 2009
    Tampa, FL
    Check the exterior dimensions and the interior dimensions. My guess is that the interior is smaller because the windows are mounted to the exterior brick veneer and back up to the interior stone/concrete. If that's the case you can just caulk that lip at the stone/concrete, slide a window into the brick opening (Which should be square.), attach it with Tapcons, and caulk the exterior joint. If the interior dimensions are significantly smaller it's a slam dunk. If it's only marginally smaller you're going to have to tear out at least one window to determine construction.
    In any case if you frame/buck the opening I'd suggest all the wood be replaced. Those windows are very old and I suspect the wood is seriously degraded.
  5. #20
    Jan 2008
    What I did was determine the minimum rough opening height and width and order the window to fit with 3/8" gap all the way around. This allowed me to shim the window squarely in the concrete RO & secure with tapcons into the concrete. I then sealed the gap with the minimal expanding foam.
    For my small basement window I used PVC quarter round to trim out the exterior, mounted and sealed with an adhesive silicone based caulk. I have 24" overhang eaves so my windows do not see much rain unless it is blowing sideways.
  6. #21
    Thanks for all the advice. I think I will be building a buck out of 2x6 treated lumber. I will probably use Tapcon blue screws, but was wondering- is there any type of brick anchor that doesn't require pre-drilling? This might simplify the installation. Thanks for any help, again.
  7. #22
    Brick is probably soft enough that you could use a powder charged nail gun like a Ramset, but I think it might shatter the brick. Also, I've never tried it so you would have to check to be sure it would work before pulling the trigger. I think a hammer drill and Tapcons are the best way to go in your situation.
    -rick
  8. #23
    Yep, I think tapcons and hammer drill would be best too. Thanks all for the help!
  9. #24
    DIY Junior Member lynnbrwn's Avatar
    Mar 2012
    Washington, D.C.
    For a basement window, in my opinion, I would go with vinyl or aluminum with spray foam insulation.
    When you undertake a interior remodeling project, first do your research so you can produce a beautiful home and keep the costs down.
  1. Replacing old metal basement windows
    By Ian Gills in forum Remodel Forum & Blog
    Last Post: 11-16-2012, 02:49 PM
  2. Framing inside basement glass block windows
    By cacher_chick in forum Remodel Forum & Blog
    Last Post: 03-13-2010, 10:35 PM
  3. Replacing Pipes Under Basement Floor
    By Sir Isaac in forum Plumbing Forum Discussion & Blog
    Last Post: 04-10-2009, 10:12 AM
  4. Replacing Sewer Drain Cap in Basement Floor
    By LFM in forum Plumbing Forum Discussion & Blog
    Last Post: 05-06-2008, 06:42 PM
  5. Replacing basement shower with bathtub..??
    By JohnnyAppleseed in forum Shower & bathtub Forum & Blog
    Last Post: 09-02-2006, 11:21 PM
