Thread: How can I cut tile/cement board floor already installed?
    DIY Junior Member sproksch's Avatar
    Apr 2010
    Virginia
    Question How can I cut tile/cement board floor already installed?
    Hello,
    I apologize if this has been covered - I did some searches and haven't found much.
    I'm remodeling my shower. I removed the old shower tray, which rested on the subfloor. The rest of the bathroom has 1 inch thick cement board with tile atop. I need to cut this back about 1 inch so I can accommodate the new shower tray. Eventually, the whole floor will be covered with new vinyl, so I'm not worried about damaging the rest of the tile in the process - just need the extra inch. What's the easiest way to cut this back? It was thinking of chiseling it away, but that would take a while, and not leave a very clean edge. But I suppose I can fill that in after the new tray is in.
    I appreciate any advice!
    thanks,
    Steve
    Jan 2008
    Get a 7" diamond blade and put it in your circular saw. Set the depth 1/8 less than you need it to be and make your cut.
    It will make an EXTREME amount of dust, and it would be helpful to have someone right there holding a vaccuum cleaner hose to try to suck up the dust coming off the blade while you cut. Ventilation, safety glasses, and a dust respirator are highly recommended.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I use an angle grinder with a tile blade for this type of project. As stated above it will make a lot of dust. Some times I cover my work area with clear plastic and wear a mask to keep the dust out of the rest of the house. You could open the window and put a fan in the window blowing out and most of the dust will go out the window. Good luck
    Apr 2010
    Virginia
    Awesome - thanks for those suggestions; just what I was looking for!
    thanks!
    Steve
  1. Cement board help needed!
    By uptownbecky in forum Shower & bathtub Forum & Blog
    Last Post: 11-14-2009, 06:34 PM
  2. laying down vinyl tile on painted cement basement floor
    By sandiphi in forum Remodel Forum & Blog
    Last Post: 04-13-2009, 09:34 AM
  3. Large corner gaps between installed cement board
    By jackcracker in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2008, 11:29 AM
  4. Finishing Cement Board
    By viennamicro in forum Remodel Forum & Blog
    Last Post: 09-30-2007, 07:21 PM
  5. How much green board or cement board for shower
    By jeffxjet in forum Remodel Forum & Blog
    Last Post: 10-26-2004, 11:00 AM
