Results 16 to 30 of 45
Thread: Grout or Caulk at Tile corners?
  1. #16
    DIY Junior Member scottl44's Avatar
    May 2011
    Walnut Creek, CA
    It takes more than 15 minutes to get the black stuff off?
  2. #17
    Janitorial Technician nestork's Avatar
    Aug 2012
    Winnipeg
    That black stuff is mildew. It's a fungus that feeds on the vegetable oils found in bar soaps, like the palm and olive oils from which the Palmolive company got it's name.
    That's why you never see mildew growing on ceramic tiling above a bathtub in a house where people have baths instead of showers. It's the soap that gets deposited onto the walls in a shower that provides the food supply mildew needs to survive and multiply. When someone has a bath, neither soap nor soap scum will ever get more than an inch or two above the tub, and so you never see mildew on the grout in a house where people have baths instead of showers ('cept for an inch or two above the tub).
    When I clean mildew off silicone caulk, I leave the Borax/Bleach slurry on for several days. However, I've found that most of the cleaning occurs within 24 hours. If you don't have another bathroom you can use to shower or take a bath, just cover the slurry with 2 inch wide painter's masking tape, and then cover that painter's masking tape with packaging tape to make for a moisture-proof seal.
    Then shower normally and take the tape off in a few days. Then, remove the dried up borax/bleach slurry with a putty knife (being careful not to harm the underlying silicone caulk) and you should find that your silicone caulk is spotless. (That slurry won't have actually "dried"; it'll have solidified. The water in it gets bound up in the solidified stuff just like the H2O in the gypsum core of drywall.)
    PS: Boron is a natural fungicide just like zinc and copper. In both zinc naphthalate and copper naphthalate wood preservatives, it's the zinc and copper that are the active ingredients. Boron is the active ingredient in borate wood preservatives like Tim-Bor and Borocol liquid wood preservatives as well as Impel and Cobra Rods which are also boron based. So, by mixing Borax into the bleach to make the slurry, you've got a natural fungicide in your slurry, thereby making it more effective at killing fungii than if you'd made the slurry using any other powder.
    PS #2: I expect you could probably eliminate the possibility of mildew growing on your silicone (or anywhere) by using a skin cleanser that didn't have any vegetable oils in it, like either Cetaphil or Aquanil, both of which are available at most drug stores. Both Cetaphil and Aquanil advertise themselves as being "lipid free", and that's just means they don't contain any "fatty acids" which is what vegetable oils and bar soaps are made of. And, it's those lipids that mildew eats to survive and multiply. So, by switching from using a bar soap to a "lipid free" skin cleanser in your shower, I'll bet dollars to donuts that you won't ever have any mildew anywhere in your shower. That is, by using a lipid free skin cleanser, you deprive the mildew in your shower of food, and whatever mildew is inside your shower slowly starves to death.
    So, you could clean the mildew off your silicone caulk with a borax/bleach slurry or switch to a lipid-free skin cleanser and wait for nature to take it's course. Or, do both and prove to yourself that the mildew doesn't return as long as you're not feeding the mildew in your shower with fatty acids from the bar soap you're using.
    Ya gotta know this stuff to be worth your salt as a janitor.
  3. #18
    May 2011
    Walnut Creek, CA
    Fantastic. I had no idea. Just a couple more questions.
    Since the soap goes all over the shower and not just on the caulk, why doesn't it grow on the tile or the grout? It does seem to get on parts of the metal door frame though.
    I have a steel sink in my kitchen with clear caulking where it meets the granite counter top. Some of that same black discoloration is in the clear caulk and I've rarely, if ever got any soap in these areas. Any ideas here? Will the bleach/borax work on this too?
    Are there any bar soaps that don't have the fatty acids?
  4. #19
    Aug 2012
    Winnipeg
    For some reason, every time I post, the post ends up being posted twice.
    This was exactly the same as the following post before I changed it to a two sentance post.
  5. #20
    Aug 2012
    Winnipeg
    Quote Originally Posted by scottl44 View Post
    To answer this part of the question, you need to know that there are two kinds of grout; epoxy grout and cement based grouts. Epoxy grouts are impermeable plastics and never need to be sealed to prevent mildew from growing on them. Cement based grouts (both sanded and unsanded) dry porous and need to be sealed to prevent mildew growing on them. So, if you have epoxy grout, you'll never need to worry about mildew growing on your grout, and so the rest of this post will confine itself to cement based grouts.
    In a nutshell, the reason why there's no mildew growing on your grout yet is because it's still too alkaline, and therefore not to the mildew fungii's liking. But that will change with time as described below:
    There is a cycle in nature called the "Lime Cycle" and it's important for every DIY'er to know and understand that cycle and how it affects masonary products, like concrete, concrete blocks, brick mortar and cement based ceramic tile grouts.
    Here is the "Lime Cycle":
    Marble is nothing more than limestone that's been compressed by the weight of the Earth's crust or oceans and heated by geothermal heat. So, when Rome fell, Roman citizens pulled the marble off the walls of the Colloseum and other public buildings and burned it in fires to make a white powder called "quick lime" or "calcium oxide" (formula: CaO). When you mix quick lime with water, you get a slurry called either "slaked lime", and if you let that slurry dry to a powder you have "hydrated lime" or "calcium hydroxide" formula: HO-Ca-OH, which is the "lime" we mix with portland cement and aggregate to make concrete mix in bags. We also mix that lime with portland cement and sand to make brick mortar. We mix that lime with white cement and sand (or not) to make unsanded and sanded ceramic tiling grouts and we mix that lime with Plaster of Paris to make real lime based plasters for the interior walls in older homes.
    But, take a look at the formula for hydrated lime powder: It's HO-Ca-OH, and it's those hydroxyl groups (-OH) that makes the lime highly alkaline. So, when you mix hydrated lime with porland cement, sand and/or Plaster of Paris (which is gypsum), the slurry you get is highly alkaline, and as it solidifies it remains alkaline... for anywhere from about a year to two years.
    During that first two years the alkalinity of fresh concrete, brick mortar, lime plaster and ceramic tile grout will diminish as the CO2 in the air reacts with the hydrated lime to form calcium carbonate, which is the principle constituent of limestone, like this:
    HO-Ca-OH + CO2 makes CaCO3 plus an H2O molecule (which turns into a butter fly and flies away).
    So, the lime added to your ceramic tile grout when it was manufactured is gradually turning into limestone, and as it does those hydroxyl (-OH) groups in the grout disappear and the alkalinity of the grout subsides.
    How that affects you as a DIY'er is that you have to be careful painting fresh concrete or concrete blocks because if you use an oil based paint, the fatty acids in the oil will react with the high alkalinity of the concrete to convert the oil based paint into a crude form of soap, and the result will be that the paint will disintegrate on the fresh concrete, concrete blocks or lime based plaster. That reaction is called "saponification", and all soaps are made by using that saponification reaction to convert animal or vegetable fatty acids into soap in the presence of a strong alkali.
    aside (If you have to paint fresh concrete, you can use a special acrylic primer made for this purpose on it after only a month or two, and then paint over that primer with any paint you want. The primer effectively acts as a physical barrier between the highly alkaline concrete and the top coat of paint. Once concrete, concrete blocks, brick mortar and the like are more than 3 or 4 years old, their alkalinity will have subsided sufficiently that you can paint them with anything without concern about alkalinity being an issue.)
    In the case of your bathroom walls, THE ONLY reason mildew isn't already growing on your grout is that it's still too alkaline for mildew's liking. As the alkalinity of your grout diminishes, you'll find more and more mildew starting to grow on it, and in time you could be looking at something like this:
    Mildew won't grow on the surface of wall tiles because ceramic wall tiles are glazed, and so the smooth glazed surface of the tiles prevents the mildew spores from grabbing onto anything to anchor themselves in place. Basically, they get water cannoned off the glazed wall tiles by the water spray and end up going down your shower drain. Porous grout, on the other hand, is a mildew spore's idea of heaven. It has a strong porous surface that mildew fungii can root itself into well, and a continuous supply of food every morning and many friday and saturday evenings.
    Bar soaps are most commonly made by combining vegetable oils with sodium hydroxide (formula: NaOH), also called "oven cleaner". If you use potassium hydroxide instead of sodium hydroxide, you tend to get liquid soaps like skin cleansers. To mildew, it doesn't matter what kind of soap it is, as long as it's got fatty acids in it, it's food. It's very possible that you have some liquid soaps on your bathroom vanity that may have gotten onto that caulk.
    My experience has been that the less time mildew has grown in an area, the easier it is to remove with a borax bleach slurry.
    I very much doubt that bleach would harm your granite. Bleach works by releasing lone oxygen atoms, and those lone oxygen atoms react with anything unstable enough to react with them, and those tend to be things that would decompose on their own given time, such as large organic molecules. The stuff in granite won't decompose on it's own no matter how much time you give it, so I expect any kind of natural stone is too stable to be affected by bleach. I'd say that the bleach/borax slurry would work equally well on the clear caulk around your sink, too. If it turns out that it doesn't, it's not hard to remove caulk and replace it. It's just that with silicone caulk, you need to remove it completely before the new silicone will stick.
    I would say that every bar soap will be made of vegetable oils (and in rare cases, animal fats) and so every bar soap will contain fatty acids.
    The difference between a detergent and a soap is that a detergent is a synthetic soap. It's made out of chemicals, but it's works the same way as soap to emulsifying soils in water. The advantage to detergents is that they can be formulated to avoid a lot of problems inherent in soaps. For example, the reason you never see a soap scum ring in your KITCHEN sink is because you don't use bar soaps in your kitchen sink. You use dish washing detergents in the kitchen sink that can be formulated to either not react with the hardness ions in water, or to not lose their solubility in water even if they do react with the hardness ions.
    So, if environmentalists use Dawn dish washing detergent to clean the crude oil off ducks and pelicans after an oil spill, I'd say it'd be worth a try using Dawn dish washing detergent in your shower to at least avoid getting soap scum all over your walls, and hopefully deny food to the mildew spores in your shower.
    I don't know whether there's any vegetable oils in Dawn, so I'd trust a skin cleanser that advertised that it was lipid free to deny mildew a source of food before I'd trust a dish washing detergent to do that.
    PS:
    You can learn an awful lot about the chemistry of cleaning at the American Cleaning Institute's web site (formerly called the American Soap and Detergent Manufacturer's Association) at:
    http://www.cleaninginstitute.org/
  6. #21
    May 2011
    Walnut Creek, CA
    Thanks so much for your detailed answers!
  7. #22
    Aug 2012
    Winnipeg
    Also, if you want to know how bleach actually works to kill mildew, read this post I wrote on a DIY forum I used to post on:
    http://www.homerepairforum.com/forum...-fan-ions.html
    I own a small apartment block and so I have to know about this stuff to protect my investment. My business wouldn't be nearly as successful and I wouldn't be able to attract desireable tenants if my bathrooms looked like the one pictured above.
  8. #23
    May 2011
    Walnut Creek, CA
    Hi guys,
    Back again.
    Now that my little girls are getting bigger, they want to start taking showers, so I need to install a sliding door over the tub.
    Anyway, the same contractor used grout in the corners of that shower and it's cracking so I'm going to strip it out and caulk the corners.
    My question is which caulk to use? I tried some GE silicone in the other shower but it seems like it gets black mildew within a year or two.
    I found this DAP Silicone Plus Premium Silicone Rubber Sealant
    Can anybody let me know if this is a good choice to use for all my change of plane joints, or is there something better?
    Thanks a lot,
    Scott
  9. #24
    Jul 2009
    North Vancouver, BC
    Post(s) deleted by John Whipple
  10. #25
    May 2011
    Walnut Creek, CA
    If it was moisture from behind, wouldn't the caulk be discolored all the way through? I can dig or scrape at this stuff and see the caulk color underneath.
    Which shower do you mean, the one that's done or the one I want to do?
  11. #26
    May 2011
    Walnut Creek, CA
    I have gotten used to putting sealer on grout, but I never actually knew why.
    Is it to keep water out, or to keep the grout from staining?
    Thanks,
    Scott
  12. #27
    Grout (and it helps on some tile as well) sealer is primarily for helping to prevent stains. While it may have a short-term water beading capability, it is not a filler that prevents water from migrating through the surface. A typical glazed tile doesn't benefit, nor does a straight porcelain tile unless it is polished, then the pores are opened up, and it should be sealed as well as the grout. A urethane and epoxy based grout typically does not benefit from sealing, only cement based ones.
  13. #28
    Mold behind silicone only means the silicone should have been replaced before the water got behind it. It's not permanent material. Remove the silicone, allow the joint to dry out thoroughly, and then install new silicone.
    John Bridge, Ceramic Tile Setter :-)
    http://johnbridge.com/vbulletin/index.php
  14. #29
    May 2011
    Walnut Creek, CA
    I just have Custom's non-sanded in 1/16" joints.
    I always had thought sealer was to keep out water. So is it normal and permissible to have water leech in to those joints? It doesn't cause any water damage inside the wall?
  15. #30
    A properly built shower isn't damaged by moisture even before the tile is installed. Except maybe in a commercial shower or steamroom, the shower is not typically used more than an hour or two each day, so it has time to dry out. Sealer is primarily designed to help prevent staining, but it does help slow, but not stop, moisture. On a conventional shower pan build, they put weep holes underneath the tile for a reason...gravity helps move any moisture that does get there down the sloped liner and out the drain. ON a wall, it primarily dries to the outside.
    The reason I prefer a surface applied membrane is that there is so much less in a shower that can get wet in the first place on both the walls and the pan, so it will dry out much faster than a conventional shower built over materials that can absorb moisture, and, I feel, is a much better solution to a shower that gets heavy use.
  1. Hardibacker and tile install questions - corners
    By kjm in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2010, 05:07 PM
  2. Moisture coming up through tile grout.
    By masmia in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-16-2008, 08:24 PM
  3. Caulk or grout?
    By evdryst in forum Shower & bathtub Forum & Blog
    Last Post: 11-17-2008, 07:54 AM
  4. Sealing Tile Grout
    By Schook in forum Remodel Forum & Blog
    Last Post: 04-30-2007, 09:46 AM
  5. Grout or Caulk Corners?
    By Lakee911 in forum Shower & bathtub Forum & Blog
    Last Post: 09-01-2005, 07:17 PM
