Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: Water Line Inside Sewer Pipe
    DIY Junior Member rugoofy's Avatar
    May 2011
    Rockford, IL
    Default Water Line Inside Sewer Pipe
    My neighbor had a new water line installed. When the company they hired pushed the water line through the ground they hit and broke my sewer line, which is actually a community sewer line that I share with at least one other neighbor. Since they had their water line installed I have been getting sewage backing up into my basement about once every 3-4 weeks. I've tried talking to my neighbor and the company that installed their water line but haven't gotten anywhere with them. The company that installed the water line says its not their fault because they didn't know the water line was there and my neighbor doesn't want to pay to get it fixed. Does anyone here have any suggestions for me? Can I go to the water department and get their water line condemned until they get it fixed? I'm not sure what I can do short of hiring a lawyer and sueing them so anything would help. thank you very much.
    Jan 2008
    I wouldn't be on the internet asking questions, I would be talking to the municipality. There are specific rules that govern the positioning of a potable water line in relation to a sanitary line, and it is apparent they did not follow them.
    The neighbor should repair any lines that were broken.
    It's his water service replacement that caused the damage.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    The first thing that is done before any excavating is to get locates for any underground services. If they did this and still hit something they are still liable to fix it.
    Locates don't establish where the sewer line to a property is.
    Only for things like
    Gas
    Electrical,
    Telephone
    Cable
    Locates don't find side sewers or water services.
    The contractor should fix the line where it has been broken, but the homeowner is contracting and paying for the work.
    Is the homeowner saying, Sorry, I hired a hack and now it's "your" problem?
    I can't imagine replacing someone water service, drilling and ruining a sewer line by accident and then just leaving the job.
    Yakima WA
    Unless you get immediate action to remedy this, I would urge you to contact an attorney. If there is need for legal action, to sooner the attorney has the case, the better. You should not have to fight this on your own. Trying to be Mr. Nice Guy and avoid hiring legal help is just asking for trouble.
    I once had a job where the telephone company drilled their wire through a sewer, and they made the repair. NOT KNOWING where sewer lines are is a constant problem, as is drilling through them, but when it is done, whoever did it IS responsible for the repair. Here, you would call the Arizona Registrar of Contractors to "force" them to fix your sewer. (And if the did not, the state WOULD repair it, deduct the amount from the contractor's bond, then put them out of business until they repaid the amount), Illinois should have a similar agency.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I do not think you could get his water line condemned because it is under pressure. If a hole comes in the water line, it will leak out ,not into the water line. If your sewer line is clogged, you have no choice but to snake it out. If his water line is in there and gets broken or mashed so what? Also it may be some other problem that just happened about the same time. Could just be a coincident and not their fault, unless you saw or know for sure they broke your sewer line.
    I would snake the sewer with a rotary saw blade. IF the water line is through the sewer, then that would take care of that problem, and it would NOT be your responsibility because it was broken.
    If it's a plastic line, then a snake should be able to cut the line.
    The gas company ran their gas line through my mothers clay tile sewer line. When it was snaked, it cut the gas line. It was a lot of fun after that for the gas company.
    This was the high pressure plastic line before the pressure reducer.
    Lucky for my mother, was that the plumber was using an outside cleanout.
    Otherwise, the home could have filled up with gas and exploded.
    Dec 2007
    They are lucky they didn't end up building her a new house...
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    Helloooo!
    Calling RUGOOFY - are you still here?
    May 2011
    Rockford, IL
    Thanks for all the replies. They did contact J.U.L.I.E. and the sanitation dept. but the sanitation dept. didn't know where the sewer lines were at. Terry - They have basically said that since your the one getting the sewage in your basement and we're not it's your problem. It is a plastic water line but instead of crossing the sewer pipe it runs in the same direction as the pipe for about 2-3 ft. then goes back out making it difficult to break the line. I like the rotary blade idea. I might try that the next time I clean it out. I've had it cleaned out 7 times now but the water line is still intact. One thing I forgot to mention is that the sewer line is a community sewer line with 3 houses connected to it. Mine is the lowest lying house on the line and of course the person who had the water line installed is the highest. I have contacted a lawyer in case it has to go that far and have contacted the property standards dept. for Rockford, IL. to see if I can get the city to shut their water off. and hj I'm looking to see if Illinois has something similar to the Arizona Registrar of contractors.
    Gas lines through sewer lines are becoming a problem for sewer cleaners. And when you cut one you have to be "quick" to exit the house and take everyone in it with you because as soon as the gas reaches an ignition source the house is going to "GO" away.
    Dec 2007
    A blade like this one should do a nice job of cleaning your sewer...
  1. Condensate Line to Sewer Pipe, NSPC
    By PrezMFL in forum NSPC Plumbing Code Questions
    Last Post: 06-07-2010, 08:55 AM
  2. Capping off old sewer pipe inside house
    By natemac in forum Plumbing Forum Discussion & Blog
    Last Post: 04-19-2008, 11:04 AM
  3. Dark brown goo inside copper water line
    By T. Scott in forum Plumbing Forum Discussion & Blog
    Last Post: 04-09-2008, 09:43 AM
  4. Repairing Sewer Pipe from inside
    By Lakee911 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-04-2008, 09:06 PM
  5. Sewer line pipe size
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 06-07-2005, 02:16 PM
