Results 1 to 15 of 15
Thread: Installing a Kohler Rite-Temp bath & shower valve, K-304
Hybrid View
    Default Installing a Kohler Rite-Temp bath & shower valve, K-304
    Installing a Kohler Rite-Temp pressure balance bath & shower valve, K-304
    Rough in instructions from Kohler with some added tips.
    Most plumbers will remove the cartridge, and solder pipe to the valve body first, and then reassemble the valve. The valve comes with the option to thread on a "female adapter", or to insert copper pipe into the brass body of the valve. I prefer to solder copper pipe to the valve.
    two
    two, The pipe to the tub spout needs to be full size. No PEX here. PEX is undersized for a tub spout and will force water up toward the shower head. Either copper or threaded pipe like galvanized or brass. I use either copper or brass. Galvanized will rust and the first time you open the faucet in the morning, you will get some rusty water.
    three, if you have a back to back installation like below, you can reverse the valve without making the pipes cross over.
    four
    thirteen
    fourteen
    fifteen
    sixteen
    One "minor point". Valves which have the option to solder the tubing directly into the valve, have MALE threads, so you would have to use a "female" adapter, NOT a male one, to connect to the valve. And do you really think plumbers or most handymen/DIYers read the directions?
    I just went back and made that edit. It was Sunday, what can I say?
    DIY Junior Member bananavida's Avatar
    Jun 2011
    Belize
    Default K-304-K-NA installed and no water
    I have loads of water pressure however, after installing the K 304 valve and turning on the water nothing comes out except a couple of drips. It's like the flow is restricted somewhere. I removed the pressure balancing unit and confirmed that yup, loads of water pressure.
    Could my pressure balancing unit faulty right out of the box as it seems to be restricting the water flow to the point of nothing coming out?
    I'm at a loss.
    Any help would be appreciated. THanks
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Is it a tub and shower Or shower only? If shower only check restricter in shower head.
  1. Water supply and pressure with Kohler Rite Temp valve.
    By Designie in forum Shower & bathtub Forum & Blog
    Last Post: 10-27-2010, 02:36 PM
  2. Problems with Kohler 304-KS-NA Bath and shower Rite-Temp Valve with stops
    By j_and_c in forum Shower & bathtub Forum & Blog
    Last Post: 03-23-2010, 10:02 AM
  3. problems with kohler Rite-Temp shower valve
    By Annec in forum Shower & bathtub Forum & Blog
    Last Post: 10-02-2008, 03:57 PM
  4. Kohler Rite-Temp 304 Shower Valve
    By basementshower in forum Plumbing Forum Discussion & Blog
    Last Post: 03-17-2007, 03:59 PM
  5. Kohler Rite-Temp Valve Disassembly
    By ziggy96 in forum Shower & bathtub Forum & Blog
    Last Post: 10-05-2005, 10:02 AM
