Results 1 to 3 of 3
Thread: ABS to PVC Septic Connections
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default ABS to PVC Septic Connections
    Need to connect 3" PVC to a 3" black ABS pipe which exits an old septic system at a newly acquired cottage.
    The pipe run is through a open crawl space under the cottage. Do I use SCH 30 or SCH 40 pipe. Advantages or disadvantages of either?
    Also, would the 3" Black ABS pipe match SCH 30 or 40? I will of course be making my rough drain connections throughout the cabin from the PVC.
    I have purchased the "Green Bottle" ABS to PVC cement. Is it true that you only primer the PVC and NOT the ABS (hearing that it dissolves ABS)?
    Thanks.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Fernco will have list of products,you cannot glue pvc to abs,pvc is solvent weld,abs is glued non compatable materials. fernco might have solve your problem.
    Clay
    Nov 2010
    Maine
    There are only two approved methods for joining PVC and ABS and glue ain't either of them. You either need a banded coupling (indoors) a non banded coupling (outdoors) or male and female adapters.
  1. Al to Cu Cooktop Connections
    By TubeGuru in forum Electrical Forum discussion & Blog
    Last Post: 09-09-2010, 05:57 AM
  2. S-Connections
    By Nettlewarbler in forum Shower & bathtub Forum & Blog
    Last Post: 08-24-2009, 06:23 AM
  3. Shallow well connections
    By Brian78753 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-11-2008, 06:06 AM
  4. Septic gas belching past full p-traps/ Septic tank drainfield failing? Venting issue?
    By ryan100 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2008, 06:49 PM
  5. PEX connections
    By Wrenn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2006, 10:37 PM
