Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: XP crashed
  1. #16
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Hi Don, went to Dell`s site last night and found that I can get the drivers but did`nt know what drivers to download,Dell # jvy7k51.
    Thanks Clay
  2. #17
    Mar 2011
    Houston, TX
    Good Morning,
    Here is a link to the drivers for the Dimension 2400.
    http://support.dell.com/support/down...iceTag=JVY7K51
    Just select the Windows XP operating System, and the Audio driver is the first one.
    It looks like it uses the Intel Chipset. The Video Driver is on the Second tab, under all Dimension 2400 files.
    Looks like a nice machine.
    Good Luck
    Have a Great day.
    DonL
  3. #18
    Aug 2007
    Cincinnati OH
    Thanks Don I will try that later today.
    Clay
  4. #19
    Mar 2011
    Houston, TX
    Clay, Just a warning.
    I would not try doing the BIOS upgrade unless you are having big problems.
    Many times it will screw up the motherboard, then you do need to buy a new one.
    The Bios should be fine with the hardware on your motherboard, Intel is the most stable.
    Works good , last a long time.
    DonL
  5. #20
    Aug 2007
    Cincinnati OH
    Thanks Don for the heads up but knew not to do that,downloaded the and it came back no files exist r78764. I might just get a new sound card. We got a place here that sells all kinds of goodies for pc`s.
    www.microcenter.com And the pricing is good.
    thank again Clay
  6. #21
    Mar 2011
    Houston, TX
    MicroCenter is a cool place.
    You might want to look at your system devices under the control panel;
    Control Panel - System - Hardware - Device Manager
    Look for devices that are in Red or Yellow, You can delete them (They are not working anyway) then reboot your system and the drivers will be reinstalled.
    That sometimes will fix problem devices, that were not installed properly. The drivers should be on your machine or your install disk.
    That might be worth a try.
    Good Luck.
    Have a great evening.
    DonL
  7. #22
    Aug 2007
    Cincinnati OH
    Hi Don got the moniter back to 32 bit.
    Thanks your last post help a great deal.
    Clay
  8. #23
    Mar 2011
    Houston, TX
    Hello Clay,
    I am glad that you made some progress.
    I don't know why you had a problem getting your audio driver.
    Here is a direct link to the driver that your system uses, That is if it is the original one built into your motherboard.
    http://support.dell.com/support/down...&fileid=122481
    Did you add another audio card, or are you using the one that is integrated into the Dell Motherboard ?
    Have a Great day.
    DonL
  9. #24
    Aug 2007
    Cincinnati OH
    I tried your link it may work. thanks Don.
    Clay
  10. #25
    Aug 2007
    Cincinnati OH
    Got my sound back.
    Thanks Don.
    Could not have done it without your advice!
  1. Has your computer crashed today? This may be why
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-28-2010, 06:18 PM
