XP crashed
Cwhyu2
Consultant
Cincinnati OH
My computer went down this afternoon and had to re install XP from a disc bummer lost everything now I wd
would like to know if I can get it back and this is an older XP than I had.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Unfortunately that question should have been asked before the disk got overwritten by the reinstall. Sorry for your loss.
DonL
Houston, TX
It depends how you re-installed it.
If you low-Level reformatted the drive then it gone.
Win XP install Disks give you some options to reinstall, without formatting.
Some OEM disk use a ghost disk image, and reformat the drive.
DonL
Cwhyu2
Consultant
Cincinnati OH
DonL
Guess I will have get a new machine.thanks
DonL
Houston, TX
Why would you need a new machine cwhyu2 ?
The old ones work good.
If you have XP SP2 at least then you should be good to go. What make of computer do you have ?
HP and Compaq have the best system backup built in to a hard drive partition. Don't do much good if a hard drive fails.
But can recover from a virus. As long as the virus does not screw up the partition sectors.
Good Luck with Your project. XP is better than the newer OS. You have more control over it.
I like Your Mustang. I like My 1970 GTO but cost to much to drive it.
Enjoy Your Day.
DonL.
Cwhyu2
Consultant
Cincinnati OH
I got it working ok but no sound updated from sp1 to sp3 took over 15 hrs of downloading and installing may be worth it who knows :rolleyes:
Thanks guys!
DonL
Houston, TX
SP2 is the best.
If you update to Sp3, expect problems.
Sp3 was never made for older machines. They want you to buy a machine with Vista.
If You need motherboard drivers then Tell us system model , and we can help you.
SP3 will not have any more drivers for audio or video, for an older machine than your orginal OEM disk.
Have a good Day.
DonL
Cwhyu2
Consultant
Cincinnati OH
Thank you Don It is a dell computer it came with sp3 and a lot of windows office and other programs,it is still a good machine but I still do not like Dell. #4 cpu ,1.25 ram 33gb hard drive 53% free.
DonL
Houston, TX
Dell is OK.
The OEM disk re formats the hard drive, if you need to reinstall it. Uses a Ghost Backup System.
I never use automatic updates, Because You wake up some day after leaving it on the internet overnight,
to find that it no longer works in the morning.
Dell is OK, Windows Updates are not so much.
Enjoy your evening.
DonL
Redwood
I found OS X version 10.6.7 to be a superior operating system that eliminates many of these problems you all are mentioning...
It comes on Macs... :D
DonL
Houston, TX
Hello all,
The Mac priced itself out of the market in the beginning of the PC. Twice the money.
Giving them away to schools helped them, that was smart on their part.
Most teachers and students got them at a discount, and needed them for school work.
They are harder to work on when they do have simple electrical problems.
How do the new ones work when running Windows apps ?
I guess good software is now available, But in the beginning, Microsoft had better/more software available.
Have a great day.
DonL
Redwood
Yea Don I guess they are more expensive but sometimes quality costs more...
I don't know about harder to work on mine hasn't broken...
I have managed to find whatever software I've wanted with no limitations wanted.
Most of the things I have used such as Adobe PhotoShop actually seems to start and run much faster on the Mac...
Cwhyu2
Consultant
Cincinnati OH
Got it working but it does not recignize sound card and only 16 bit res on moniter I will fix some how.
Thanks Clay
DonL
Houston, TX
What is the model that you have Clay.
I can steer you in the correct direction. Just need the exact Dell #.
Or you can get the drivers from the Dell site.
I think it is integrated on the motherboard.
DonL
Cwhyu2
Consultant
Cincinnati OH
Hi Don, went to Dell`s site last night and found that I can get the drivers but did`nt know what drivers to download,Dell # jvy7k51.
Thanks Clay
DonL
Houston, TX
DonL
Houston, TX
Clay, Just a warning.
I would not try doing the BIOS upgrade unless you are having big problems.
Many times it will screw up the motherboard, then you do need to buy a new one.
The Bios should be fine with the hardware on your motherboard, Intel is the most stable.
Works good , last a long time.
DonL
Cwhyu2
Consultant
Cincinnati OH
Thanks Don for the heads up but knew not to do that,downloaded the and it came back no files exist r78764. I might just get a new sound card. We got a place here that sells all kinds of goodies for pc`s.
www.microcenter.com And the pricing is good.
thank again Clay
