Results 1 to 8 of 8
Thread: PEX fitting reliability
    DIY Junior Member como1103's Avatar
    Apr 2011
    Arlington, TX
    Default PEX fitting reliability
    I am installing an irrigation system in my yard, and am tapping into the main water line. It is 1" pex pipe, and I plan on using some pex compression fittings connected to a PVC tee for the sprinklers.
    My question is, how reliable are these pex compression fittings? This connection will all be buried underground, and after making sure it isn't leaking when I attach it, I will cover it with dirt and likely never see it again. If it ever begins to leak, I will never know.
    Another question... how else can I tap into a 1" pex pipe? Thanks.
    Yakima WA
    Seems to me a PVC irrigation system would be simpler and less expensive. You'd only need to transition from PEX once. I'd got to copper from the transition point to the back flow device, then transition to PVC. You could go with PVC instead of copper, that is just my personal choice.
    What do you mean by "PEX compression fittings"? The simplest would be a PEX tee with PEX to the backflow preventer, (you are going to install one, aren't you?), and then PVC from there.
    Yakima WA
    I basically concur with HJ. My choice of copper instead of PEX to the back flow prevent is just to provide a solid base for the back flow preventer. Functionally, there would be no difference.
    Apr 2011
    Arlington, TX
    Yes, I am installing a backflow device. I am running pvc from the main pex waterpipe to the side of the house where everything will be located (valve box, shutoff valve, backflow preventer, etc...)
    the fittings I am asking about look similar to this...
    They are not threaded and fit right into a 1" pvc tee. The guy at my plumbing specialty store recommended them and said they were made for pex pipe. Once I get it put together, and make sure it isn't leaking, can I cover it with dirt and forget about it forever?
    DIY Member RinconVTR's Avatar
    Sep 2009
    Wisconsin
    Quote Originally Posted by como1103 View Post
    Plumbers in my area said no worries. They use PEX very often for new homes and retro's. I happen to also T into my main line (like you are) and installed 1" PEX to feed my water powered backup sump pump.
    Until my basement floods...I have no concerns about PEX fittings and crimp rings.
    That fitting is for ips pipe, such as PVC, NOT a cts line such as PEX. I would prefer copper also, but if he is going to run plastic, PEX might be preferable since it would not snap in two when the lawnmower hits it.
    Apr 2011
    Arlington, TX
    HJ, that is not the exact fitting, that just looks similar to it. I couldn't find the exact one I used.
    I got it all put together today and had no leaks. Ill leave it exposed for another day or so to make sure its still solid, then bury it. Thanks for the help
  1. Liberty Pump Switch Reliability
    By wraujr in forum Plumbing Forum Discussion & Blog
    Last Post: 03-08-2010, 03:25 PM
  2. Question about CPVC reliability
    By Otis in forum Plumbing Forum Discussion & Blog
    Last Post: 01-30-2010, 05:05 PM
  3. MOEN Faucet Quality/Reliability
    By jdkimes in forum Plumbing Forum Discussion & Blog
    Last Post: 03-27-2008, 06:41 PM
  4. Quality/reliability of Moen Faucets?
    By jdkimes in forum Shower & bathtub Forum & Blog
    Last Post: 03-26-2008, 06:11 PM
  5. slip joint reliability and ferncos
    By adrianmariano in forum Plumbing Forum Discussion & Blog
    Last Post: 03-28-2007, 06:15 AM
