Is Softened Water Safe to Drink?
AliceCooper
Boston, MA
So been reading this water softener FAQ and it says that in general softened water is safe to drink. But I'm still a little unsure.
If all it does is add salt to the water, I guess that makes sense that it'd be OK.
Any thoughts?
AliceCooper
Boston, MA
Thank you for the help! It is much appreciated. :)
I've been doing some research, and I do have another question, if that's allright - what about magnetic water softeners? Do they actually do anything?
DonL
Houston, TX
Magnetic Water Conditioners do work, on a large scale for some very expensive systems,
But not the ones you buy for a home. They are a joke.
You will get a lot of people laughing, again, on this forum.
Have a great day.
DonL
Using "salt/sodium chloride" in a softener is only a problem for people on a low sodium diet, and they can convert to potassium chloride to avoid that problem, or, as is done in most cases, install a reverse osmosis system for drinking water.
DonL
Houston, TX
That filter is nice , but not cheap.
Properly Softened water is safe to drink.
DonL
