Results 1 to 8 of 8
Thread: electrical testers
    Jun 2007
    North Carolina
    Default electrical testers
    What type of electrical tester do you use?
    Does it have a rating such as Cat I, II, III, or IV?
    Plumber jimbo's Avatar
    I have a Fluke 77, Simpson 260, an Ideal clamp on, and several assorted little digitals and analogs. Also sound level meter, laser thermometer, etc.
    Mar 2011
    Houston, TX
    Hello all,
    The Simpson 260 is one of the best meters used today, Still after all the years.
    Sometimes Older is Better...
    DonL
    DIY Senior Member Rich B's Avatar
    Sep 2008
    New Jersey
    At work on the job doing machine repairs and for automotive type work..... I have a Fluke 83 for nearly 20 years and a smaller DVM from our hardware supplier Kimball Midwest. Both read voltage-resistance-diodes-amps and the Fluke also can read HZ. Leads are 600 volt rated...
    I do repairs on welders that have an HF output or over 3000 volts and at 1 million HZ.......You cannot have a Fluke meter anywhere near that HF output when it's triggered or it's toast.....
    At home around the house.......I have a few of those pen type contact testers and also a couple cheap small live voltage probe testers that light when voltage is present.
    I used both at my next door neigbors on Easter to help him. The contact testers are very unreliable but better than nothing......They trigger far too easily but it errors on the safe side of working with electrcity...
    Mar 2011
    Houston, TX
    Default Iec61010
    Hello all,
    JW are we going to be getting a class on measuring devices and their Cat ratings as per IEC61010 ?
    Should be a good class.
    Have a great day.
    DonL
    Jun 2007
    North Carolina
    Hello all,
    Have a great day.
    DonL
    wasn't planning on doing a class but hoping to find out how many was having the problem found here
    Jun 2007
    North Carolina
    Simpson 260,.
    Hello all,
    DonL
    Which series do you have?
    I lke the 4M series as it has a mirror for a better reading
    Sep 2008
    New Jersey
    I used a Simpson today to test some components in an Inverter/Welder. An analog meter was specified for testing to get accurate readings. We have a couple Simpson meters in like new condtion and their better models. I used a known resistor to check it for accuracy and it was very close....Took me a couple minutes to get it set right for what I was testing.....Worked perfect
    The Simpson is a 260 and came from Lucent.....Has calibration stickers from 1997 on it.
    The owner of the co. I work for likes stuff like this and probably bought this one at a garage sale...
  1. Need some recomendations on Electrical Testers
    By soundguy_99 in forum Electrical Forum discussion & Blog
    Last Post: 11-09-2010, 10:44 AM
  2. Electrical Engineer allowed to do Electrical work?
    By willijimon in forum Electrical Forum discussion & Blog
    Last Post: 03-05-2009, 05:08 PM
  3. More DIY electrical
    By jar546 in forum Electrical Forum discussion & Blog
    Last Post: 12-29-2008, 05:08 PM
  4. DIY Electrical
    Last Post: 12-24-2008, 09:35 PM
  5. plumbing and electrical
    By jodenmel1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-02-2008, 05:23 PM
