Thread: tub drain linkage assembly not stopping water
    DIY Junior Member karkalec's Avatar
    Apr 2011
    charlotte, nc
    Default tub drain linkage assembly not stopping water
    Hi There,
    I'm a total amateur and am trying to get my tub drain to stop water so my little girl can take a bath. I removed the face plate and there was no part of an old linkage assembly behind it except a cotter pin left over. I stuck a coat hanger down in the hole and could fish out nothing, although I did get the coat hanger stuck for a few heart-stopping seconds.
    This morning I bought a Danco tub drain linkage assembly at Home Depot. I noticed it was the only option they had and assumed they were standard size for that reason. When I tried it out it did not stop the flow of the water out of the drain. I tried adjusting it to various lengths including making it as long as possible so I could feel it resting on the bottom of the pipe (it went in very smoothly and I couldn't feel any parts of the old assembly down there when I was feeding it in). Water still drains out of the tub regardless of where the drain stopper is. Anybody have any idea why this is so?
    Justin
    The drain assembly you bought does not line up with the existing drain. Just go get a rubber stopper for the tub, 3.00 and you are all set, then, add child & bubbles.
    Drain assemblies are NOT generic. Remove the "drain" from the bottom of the tub and convert it to a "push/pull" unit with a plain overflow plate.
  1. Shower Drain Pipe too Short for Drain Assembly
    By ilovedogs in forum Shower & bathtub Forum & Blog
    Last Post: 07-18-2009, 08:19 AM
  2. Water in sump pit consistantly filling, but stopping at drain pipe. Problem?
    By videodronetnl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-19-2008, 06:56 AM
  3. Stopping a leak at the cold inlet of water heater
    By SEast in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2007, 06:00 PM
  4. Old Crane Stopper Linkage -- Down the Drain?
    By allthumbs in forum Shower & bathtub Forum & Blog
    Last Post: 05-27-2006, 01:57 PM
  5. never stopping water pump question
    By ctutuncu in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-19-2004, 07:37 AM
