Results 1 to 2 of 2
Thread: Vespin II install on tile
    DIY Junior Member danix's Avatar
    Mar 2011
    Walnut Creek, CA
    Default Vespin II install on tile
    I'm going to be installing a pair of Vespin II toilets.
    The floor is concrete slab, and I am using a porcelain tile on the floor.
    I have cut out a circle in the tile so I can drop the tile over the flange in the floor.
    My question is whether or not I have to use a riser/adapter.
    The paperwork with the Vespin suggests that I do. But I put the unifit over the flange (without wax ring) and I don't think it will be necessary.
    How high can the tile be before you need this adapter to raise it up?
    If one wax seal doesn't compress, then you may need two wax seals.
  1. Vespin II install
    By FJK in forum Toilet Forum discussions
    Last Post: 09-17-2010, 01:32 PM
  2. Potential Toto Vespin install problems
    By Lakee911 in forum Toilet Forum discussions
    Last Post: 09-13-2008, 09:05 PM
  3. tile shower install
    By gfe76 in forum Shower & bathtub Forum & Blog
    Last Post: 11-06-2007, 06:44 PM
  4. Install bathtub over tile?
    By Xenomorph in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-31-2006, 07:24 AM
  5. Tub install -drop in on top of tile?
    By Finkeeper in forum Shower & bathtub Forum & Blog
    Last Post: 06-16-2005, 04:18 PM
