Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 2 inch packer ejector stuck in well
    Mar 2011
    Houston, TX
    Default 2 inch packer ejector stuck in well
    Hello Pros,
    I am new at posting on this forums, But I have been reading so very cool stuff here.
    First off I want to thank Terry Love.
    My problem is that I have a 2 inch well in Houston, It is 2 inch PVC Well Casing and a 1.25 inch PVC drop tube. The casing is 40 feet, the drop pipe is 30 feet and the static water level is about 20 feet this time of year.
    My pump was not making pressure so I pulled the drop pipe to take a look at the Packer/Jet.
    The problem is that the Jet assembly was cast iron and our water here ate it up, and it is stuck in the casing.
    My question is; Can I just cut off 1 foot of my drop pipe so my new Brass Packer will be above the top of the old stuck one , and just leave the old one in the well casing.
    The Venturi did come up in the bottom of my drop pipe but the foot valve and Jet assemble is still in my casing and will not budge. Leathers must have it stuck.
    How do you guys deal with a problem like this ?
    I was just going to leave the old one there, It seams to be letting water past, But I wanted another opinion.
    Thank You.
    DonL
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    This happens all the time. The water will pass through the old jet and into your new jet. I personally have one stuck in a well I maintain and it works just fine. I always leave off the footvalve and just let the internal footvalve in the jet do the work since there is already 1 regular f.v. and one internal f.v. built into the stuck jet. You'll see what I mean when you install the new jet and water comes out of the drop pipe.
    Cut off a few feet and make sure you use brass. If you need any help etc. PM me, I can either find what you're looking for or send you in the right direction. You would be much better off going to 1" PVC drop line with special adapters to attach to the jet/well head.
    Good luck.
    Mar 2011
    Houston, TX
    Thank You Texas Wellman.
    I have ordered a new Brass Packer that has a Stainless screen on the bottom of it.
    I was ready to go back with the 1.25 inch suction pipe, and have turned a 1.25 coupling down to 1 and 13/16 OD, so the jet would work better.
    What would be the pro of using 1 inch instead of 1.25 suction pipe ?
    Thank you for your help.
    DonL
    Mar 2011
    Houston, TX
    I was also wanting to know if it is better to soak the new Packer in warm water, Or will it go in easier Dry ?
    I have time to let it get wet inside of the well, But I thought going down dry may be better.
    What do you pros do ?
    DonL
    Feb 2010
    SE Texas-Coastal
    I do not like using the thin collars because of the high failure rate. The thin PVC is much more likely to break under stress or just break with no stress. I use a special adapter to go from 1-1/4 threads to glued PVC. You can get it from Gulf South Supply on airline drive in Houston if you want to use that part. Ask them for a set of SRA's, they will know what you mean. 1" PVC installes much easier and gives more clearance for the couplings etc. It also bends better and in general is just a better choice for 2" wells. The pump guys will tell you that you'll lose performance etc. but I feel that it is negligible.
    No need to soak the leathers, just flare them a bit with a screw driver. You don't need an extra footvalve in the well if there is already a jet stuck in there.
    Mar 2011
    Houston, TX
    I understand about the couplings being thin and that they could break. I will have to see if my wife will let me spend more money to get new pipe and couplings. I have already spent to much on rebuilding the pump and for the new packer. I got the new packer today and it looks good. The leathers do look small and measure less than 2 inches, so I assume that flaring them like you say would make the diameter larger ?
    Thank You for your input, I like to talk to someone that has been there, They know the good stuff.
    I retired from the oil field, working on Drilling Electronics and it is nothing like these water well play toys.
    Thanks again. Have a great Day.
    DonL
    Feb 2010
    SE Texas-Coastal
    You can get bell end PVC 1" from the big box stores about $5-6 per joint. A set of SRA's should cost no more than $20-30. You can use the 1-1/4" pvc if you wish, I just dislike it for the thin collars but it's not a terribly bad deal. I will re-use it at the customers request but I favor the 1" belled end.
    What kind of pump did you rebuild? Are you in Houston proper or the outskirts? I'm not far from Houston but down closer to the coast. I assume that this is the "garden" well, if so I would like to hear how you installed it if you did it DIY.
    Mar 2011
    Houston, TX
    Good Morning Texas Wellman,
    I hope your day got off to a good start. I live close to the great Baseball player. The pump that I rebuilt was the 2 stage Flotec FP4432 1 HP, I bought it when I worked at NASA and had more money than sense. I know it was a big time overkill for this well, but worked very good. It is the well for the house and was drilled about 20 years ago. It looked like they did it right except for using a cast iron packer. I do use it for my garden as well, but i did not install or drill it myself. It was drilled right before I bought the house. I like to fix things when I can, I say If it can break then it can be fixed. The reason I was going to use the original 1.25 inch pipe is because it is 370 psi Jet Stream, Not cheap PVC that you get these days. Thank You for the information that you provided. I was going to clean out the inside of the casing today, and get ready to install the new Brass Packer this weekend. Looks like good weather for us the rest of the week.
    Thanks again, Have a Great day.
    DonL
    Feb 2010
    SE Texas-Coastal
    The reason why a cast iron packer was used is because they are OK in a steel well. When they started putting in PVC wells in the late 70's it was not known that there would be issues with a cast iron part in a pvc well. What happens is that one part is the only part in the well that is made of iron and electrolysis eats it up. Sometimes they work OK, sometimes they get ate in two right at the hollow part as I'm sure you saw.
    That pump is not over-kill for your house. In fact if you're water level is very deep you should consider a three-stage pump (1.5 HP). I know where the baseball player lives and I have actually done a little work for him but I have never met him in person.
    The PVC that they sell at Lowe's is sch 40 rated for 450 psi and not a typically big box bad quality. I've used some and it was OK.
    Mar 2011
    Houston, TX
    Good Morning Texas Wellman and everyone,
    After thinking about switching over to 1 inch pipe in my 2 inch well like You suggested, I found that there was a 1.25 inch Iron Nipple on the top of my well head packer adapter.
    This nipple is about 6 inches long and connects to the first PVC coupling on the 1.25 inch suction pipe, and is very rusty.
    Is there a good way to remove this nipple, without breaking it off in the casing adapter ?
    It looks like if it were to break off in the adapter then I would be hosed big time, because in goes up into the adapter where
    I would not be able to remove it, in order to install the new SRA's.
    I don't want to make things worse by messing with it, but it should be replaced while I have it taken apart. I would like to do it right the first time.
    What is the trick to removing the old Nipple from the cast iron Packer Adapter ? A new adapter is about $65 and I would need one if all else fails. Money I would rather not spend.
    Have a Good Friday.
    Last edited by DonL; 04-01-2011 at 07:06 AM. Reason: Typing Error, My fault, Not the Keyboards.
    Feb 2010
    SE Texas-Coastal
    I ran into the same problem about a month ago. I just held my breath and unscrewed the nipple, it came out pretty easy but looked terrible. If it does twist off you can try an ease out or use a hack saw blade to lightly saw the "dutchman" in about 2-3 places and then pry it out. I actually went back with the old pipe on that job but I bought a sch 80 1-1/4" PVC nipple to replace the metal one.
    Mar 2011
    Houston, TX
    Thank You Texas Wellman,
    I new that you would have a good answer.
    That sound like a lot better that a Chisel and hammer, would not be able to get to it.
    I posted another thread about if maybe that could be part of the AVC system.
    Thank You for the help, You are the best...
    DonL
    Feb 2010
    SE Texas-Coastal
    It is probable that your well and the one I worked on were installed by the same guy. He always used a "green" glue and used Myers pumps. That short galv. nipple was used because there was no good way to go between the 1-1/4" pvc and the well head. That's the reason why SRA's were invented so that 1" PVC could be used. With 1-1/4 galv. it was oK to use thin metal collars but thin PVC proved to be too flimsy.
    Mar 2011
    Houston, TX
    I think You are correct about maybe the same guy that installed a lot of the same wells around here. The Glue was Green and I believe the old Pump was a Myers. Walker Water Wells was the one that installed mine, So I was told. I am still trying to get a good picture of that Square in the nipple, But I need to go back to school and learn how to use my Digital Camera. My pictures came out terrible, I will try taking them again.
    Have a great Weekend.
    DonL
    Mar 2011
    Houston, TX
    I got a picture of the square hole in the nipple. I was able to get the PVC unscrewed from the nipple but the nipple is still stuck in the adapter.
    I hope this picture posts OK, Never tried to post a picture.
    I think the square hole is just a fluke , but had me thinking.
    I hope to get this thing working soon. I have a good neighbor, and do have water in the house.
    Thank You for your help Texas Wellman, It is nice to have someone that has been there and done that.
    Here is the link;
    http://lcsc.net/terry_love/pics/sq_hole_in_nipple.jpg
    DonL
    "Beer is now cheaper than gas; drink don't drive"
    Last edited by Terry; 04-02-2011 at 06:09 PM. Reason: Trying to post picture Again
  1. Anyone know "Packer ejector" functionality ?
    By David Alan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-23-2009, 07:21 AM
  2. PE pipe work for deep well jet "packer ejector" ?
    Last Post: 12-23-2009, 06:56 AM
  3. 3 inch well casing. submersible/packer/?
    By Barnes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-15-2008, 08:03 AM
  4. 2 inch packer ???????
    By jgmap in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-07-2007, 05:05 PM
  5. 2 inch single pipe packer diagram
    By sucker dave in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-11-2006, 02:55 PM
