Thread: wireless control for baseboard heater
    DIY Junior Member yds's Avatar
    Aug 2006
    Toronto, Ontario
    Default wireless control for baseboard heater
    I have a 240V baseboard heater in my bedroom that is controlled by a built-in thermostat. I really only use it to heat up the room in the morning and evening, and it's rather inconvenient to bend down to the floor to turn it on and off each time (ok, that might sound like I'm really lazy, and maybe I am.....). Replacing the built-in with an in-wall thermostat isn't practical on the wall where the heater is (insulated wall with double-drywall making it difficult to fish wiring behind the drywall). What I was wondering was whether there was any way to get a remote/wireless thermostat, or even just a remote switch, to turn on and off the heater. I've searched for any such products with no luck. Anyone got any ideas??
    Check out www.smarthome.com or www.x10.com. It's unlikely that the heater is plugged in, it's probably hardwired, so whatever you do, you'll need to break the wire somewhere to insert the control. This could be at the unit, or maybe somewhere closer to the panel that it is fed from.
    DIY Junior Member david_griffin's Avatar
    Feb 2011
    Denver, CO
    ... or try this one http://www.cqout.com/item.asp?id=12603164
    You will also make more smart circuits...
  1. Baseboard Heater Issue
    By spta97 in forum Plumbing Forum Discussion & Blog
    Last Post: 11-12-2010, 04:04 PM
  2. Flow control Ball valve, hot water baseboard
    By Vinijm in forum HVAC Heating & Cooling
    Last Post: 04-23-2009, 02:27 PM
  3. electric baseboard heater
    By hids2000 in forum HVAC Heating & Cooling
    Last Post: 07-15-2007, 07:34 PM
  4. Adding baseboard heater
    By pressedham in forum Plumbing Forum Discussion & Blog
    Last Post: 12-12-2005, 09:27 AM
  5. Baseboard Heater Clearance
    By ohtara1211 in forum Toilet Forum discussions
    Last Post: 06-02-2005, 08:42 AM
