Thread: Kohler Bancroft Bathtub Drain and Delta Bath/Shower Rough in Valve
    DIY Junior Member GinnyQueen's Avatar
    Apr 2011
    Nashville, TN
    Default Kohler Bancroft Bathtub Drain and Delta Bath/Shower Rough in Valve
    Complete bathroom remodel and I am urgently trying to get a few more parts for the plumbers/installers. I have been learning a lot on this forum and for that I am grateful. Thank you!
    So, I am needing to purchase a drain to go with my new Kohler Bancroft soak tub. I have some options according to some sites:
    1. KOHLER K-7161-AF-BN Clearflo 1-1/2-Inch Adjustable Pop-Up Drain
    2. KOHLER K-7213-BN Clearflo Cable Bath Drain
    I am not attached to either one. I know nothing about these mechanisms only that I don't want to have to replace the drain. The cable one doesn't seem ideal, but what do I know? Are there any other drains that I need to consider that can manage all of my hair that tends to clog the toilet. Does it have to be a Kohler?
    I purchased a Delta Bath/Shower Faucet Trim T17455-SS (Victorian). There are 2 Delta Faucet "MultiChoice Universal Rough-In Valves" that are recommended to go with it from the site I purchased from: Delta R10000-UNWS (with stop) and Delta Faucet R10000-UNBX (no stop). I have no idea if I would want a "stop" because I don't think that I really know what it is. Are either of these ok? Thoughts.
    I didn't realize that there were so many extra things that I may need for the plumbers. I am just wanting to be prepared for them when they come so that I am not the reason they are held up. Are there other parts that you can think that I may need?
    Toto Promenade Pedestal sink and Two-piece toilet are my other main components.
    Thanks a million!!
    The shower rough-in valve with "stops" allows you to shut off only the tub/shower valve when you work on the cartridge.
    Otherwise you would need to shut down the entire home. It's nice to have the stops.
    You may also use something like the Gerberit cable waste and overflow; pretty much like the Koher cable drain.
    Sounds like pretty nice choices for the bathroom.
    Apr 2011
    Nashville, TN
    Thanks Terry. Glad you approve! I learned it all here (or a lot of it anyway.) So, regarding the drain, of the two I had listed, I know is the KOHLER K-7161-AF-BN Clearflo 1-1/2-Inch Adjustable Pop-Up Drain worth the extra cost? I know $100 is irrelevent at this point, but functionally, is one better?
  1. Problems with Kohler 304-KS-NA Bath and shower Rite-Temp Valve with stops
    By j_and_c in forum Shower & bathtub Forum & Blog
    Last Post: 03-23-2010, 10:02 AM
  2. Delta shower valve rough-in
    By northman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-15-2008, 11:40 AM
  3. Kohler Bancroft: Any experience?
    By NLRicker in forum Toilet Forum discussions
    Last Post: 01-13-2008, 08:14 PM
  4. Delta MultiChoice Rough In Valve
    By Mike2007 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2007, 01:20 PM
  5. Opinions/thoughts on Kohler Bancroft & Class 5 flushing system?
    By Rackon in forum Toilet Forum discussions
    Last Post: 05-23-2006, 09:02 PM
