Results 1 to 4 of 4
Thread: Water Softener - Reversed Water Inlet/Outlet hookup
    DIY Junior Member Doug8's Avatar
    Apr 2011
    Michigan Ontario
    Default Water Softener - Reversed Water Inlet/Outlet hookup
    My "plumber" reversed the water inlet and outlet hookup to the softener. I've been using the softener like this for about 3 months. Would there be any damage to the water softener from the reverse hookup?
    Thanks.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by Doug8 View Post
    Thanks.
    The only damage would be if you lost the resin. Most unit today have an upper basket that will prevent the resin from going out. When you change the piping, you can check to insure you have the proper amount of resin.
    Dec 2009
    Alaska
    Sounds like the unit that I came across awhile back, plumbers had put in a Sears unit with the in on the out and the out on the in... good thing there was an upper basket......
    Normally I find that an upper basket and iron are not a good combo... upper just loads up with to much iron an plugs up the unit.
    Apr 2011
    Michigan Ontario
    Thanks for your comments guys. I took it apart, cleaned the basket and reconnect it back the correct way. Everything is fine now.
  1. Is a flexible water and gas line to a water heater ok in Illinois?
    By paulsiu in forum Illinois Plumbing Code Questions
    Last Post: 05-26-2011, 11:30 AM
  2. Washer hookup electrical outlet box
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 06-28-2010, 09:43 AM
  3. Galvanized Tank Inlet, and Outlet
    By lzenglish in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-05-2009, 09:51 PM
  4. INlet or outlet...?
    By Diamondintheruff in forum Shower & bathtub Forum & Blog
    Last Post: 06-01-2007, 03:38 PM
  5. Preferred Config. for Rough Valve Inlet/Outlet
    By paul somlo in forum Shower & bathtub Forum & Blog
    Last Post: 03-25-2005, 03:32 PM
