water hardness and brine fill time
Jerome7
Hello everyone
I have Fleck 5600SXT valve. During the programming it asked me to enter water hardness level and brine fill time. Isn't both related to the salt dose? Why do I have to set both?
I was told the brine fill time controls how much water gets in the brine tank, thus the harder the water, the longer the brine fill time.
I left most values to the default and only entered the one I understood.
Akpsdvan
Alaska
Water hardness is used to figure how many gallons the media will treat before it needs to recharge.
Salt setting is used to give a given amount of resin a capacity, or like a battery can go x hours before it needs to recharge.
Depending on the capacity of the battery and the load ... will determine how often the battery needs to recharge for the next cycle.
Gary Slusser
That's all folks!
The refill time puts water into the salt tank based on 3 lbs of salt per gallon of water. So you select the amount of water based on the K of capacity you program based on the volume of resin you have and the salt efficiency you want.
Call the people you bought from and have them give you the programming.
Jerome7
That is now clear in my head. Thanks for the analogy.
Jerome7
Thank you Gary for the explanation. In my case, unfortunately, I bought it online and they've been giving me random suggestions for 2 months now. Thus I thought I ought to first understand how the softener works and troubleshoot myself.
