Thread: Sump Pump Activation Level
    DIY Junior Member tinye's Avatar
    Apr 2011
    OHIO
    Question Sump Pump Activation Level
    I have a continuous flow of water into my pit.
    In an effort to reduce the on-off cycle frequency of the pump, I've set the activation point of the switch a little higher up in the pit, such that it is higher than the horizontal drain tiles coming in from the side.....so the water actually backs up into these pipes as the pit fills.
    Is this a bad practice overall, and I should really be activating the pump before it reaches the drain pipe coming in from the sidewall; even if it makes the pump cycle much more often?
    Watching and adjusting this pit is an unfortunate hobby of mine
    Jan 2008
    As long as the level is maintained below the lowest point of the bottom of the slab, it should be fine. If it gets too high the water will start coming up at the wall to floor joint and/or through cracks in the floor.
    Apr 2011
    OHIO
    Great!
    That gives me much more height to work with, and allows a longer (and less frequent cycle).
    Thanks for the confirmation!
  1. Sump pump model and switch level
    By pitter in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-15-2010, 04:45 PM
  2. Reputation of ABS Robusta sump pump / sump pump configuration issues
    By ct-esq in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2008, 06:41 AM
  3. Programmed versus manual activation
    By baronoff in forum Irrigation / Sprinkler Forum
    Last Post: 07-23-2008, 07:39 AM
  4. Lower Sump Pump Level
    By smileyroget in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-30-2007, 12:03 PM
