Results 1 to 7 of 7
Thread: Leaking instant hot connector Everhot (WaterInc)
    DIY Junior Member SMBLAGBCH's Avatar
    Apr 2011
    Laguna Beach, CA
    Default Leaking instant hot connector Everhot (WaterInc)
    I'm on my third Everhot (WaterInc) instant hot water heater in three years. The problem seems to be with the John Guest union between the plastic line to the faucet and the stainless nipple. The leak causes the nipple to corrode at the top of the tank.
    Is there an alternative means of connection I could use? (The nipple gets pretty hot)
    http://www.waterinc.com/specs/everhot/Everhot-Tanks.pdf
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    If the problem is the plastic getting too hot from being too close to the water heater.
    How about adding a metal extension, put a foot of copper, add a brass nipple etc. to gain some distance.
    Michael
    They have a stainless tank with a 3- year warranty
    I have better luck with the Insinkerator Instant Hot tanks. The only tank they sell now is stainless.
    http://www.insinkerator.com/dispensers/index.shtml
    Apr 2011
    Laguna Beach, CA
    I don't know if that's the problem or not. The JG union is what the company gives you and I installed it as directed. I'd really like to find a more positive type of connection, if there is one.
    Apr 2011
    Laguna Beach, CA
    The tank looks stainless and a magnet won't stick to it. I really think the connector is the problem. Any suggestions on an alternative type of connector?
    The JG union is 3/8 x 5/16
    Nov 2005
    call anaheim, or email them. Ask about extending longevity of the tank (the next one that you will buy from them). They might tell you about water quality (what is your water like?).
    call anaheim, or email them, because (as you will see on their web site) they manufacture the tank. This tank is rebranded by MANY companies.
    In my experience, I've found that many technical support people will say anything at all, even in an email. Do not mention the JG or the union, because you do not want to give to anyone the easiest way out, in which they just agree with your preemptive diagnosis. Go to anaheim because they will know more than a rebrander. BE neutral in your query; don't bias it with your diagnosis... Hope someone writes back with a "real" answer.
    I'm not certain that it IS the union the root cause of the corrosion. Yes, this is Where Corrosion Occurs, but the cause may be ...
    Good photo!
    Apr 2011
    Laguna Beach, CA
    Turns out it's made by Kitchen Aid for WaterInc, not by Anaheim Mfg.
  1. Replacing a leaking Instant Hot tank, Property Inspector LLC, Woodinville
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2011, 07:29 AM
  2. Leaking compression connector PEX hose under sink
    By TexanLady in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-14-2010, 06:57 AM
  3. Therma-flow/Everhot water heater issues
    By chrisexv6 in forum Water Heater Forum, Tanks
    Last Post: 11-13-2009, 08:58 AM
  4. What type of connector do I need?
    By Dar in forum Irrigation / Sprinkler Forum
    Last Post: 10-28-2009, 01:31 PM
  5. faucet connector pipe leaking
    By lonomac in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-31-2008, 06:59 AM
