Results 1 to 5 of 5
Thread: A/C Slab
    DIY Junior Member burkhamerk's Avatar
    Apr 2011
    Missouri
    Default A/C Slab
    Slab under A/C Unit degrading and rear of slab sinking. A/C unit now sits at angle with rear of unit lower than front. How severe is this problem? Wondering if I should disconnect/move unit and pour a new slab.
    Jan 2008
    Most A/C places do not pour cement, they just bring in a prefabricated 3x3 slab that is available from most supply houses.
    If the condenser gets too far out of level it can effect the oil flow through the system. How much is "too much" is speculative.
    If it sinks too far, it might kink or stress the coolant lines. That can be really bad. Otherwise, close to level should be okay...hard to say how much off will cause problems.
    Feb 2011
    NW Ontario, Canada
    I would just lift the slab back up to level and shove some sand under it.
    DIY Junior Member tempritespokane's Avatar
    May 2011
    Spokane
    If the slab in not level it also can make your unit run less efficiently. In the long run it can run up your electric bill.
  1. slab under box out
    By Master Brian in forum Remodel Forum & Blog
    Last Post: 10-30-2009, 02:12 PM
  2. New DWV below slab
    By ghetterly in forum Plumbing Forum Discussion & Blog
    Last Post: 06-30-2009, 09:08 PM
  3. Trap in slab
    By garwayne in forum Plumbing Forum Discussion & Blog
    Last Post: 11-09-2008, 08:19 AM
  4. Slab leak
    By cwc000 in forum Irrigation / Sprinkler Forum
    Last Post: 11-02-2008, 06:19 AM
  5. Running Water and Drain from Slab to Slab
    By bnoji in forum Plumbing Forum Discussion & Blog
    Last Post: 05-24-2007, 05:47 AM
