Results 1 to 9 of 9
Thread: Short Bathtubs? (57")
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Short Bathtubs? (57")
    I would like to replace a steel tub that has a badly worn finish on it. However, the current tub is only 57" long. Are tubs this size available?
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Tubs are either 60" or 54" or 66" Are you measuring the tub after it has been pulled out? Or are you measuring from wall to wall?
    Most bathrooms are framed at 60-1/4", and then you add drywall and tile. If you have a mud set tile job, then even with a standard five foot tub, the wall to wall distance can be 57". Somewhere buried in all that is a 60" tub.
    Plumber jimbo's Avatar
    I wish they were framed at 60 1/4"!!! I have seen too many framed at 59 7/8" just enough off to cause problems!!!!!
    57" tubs were NEVER available. Yours is 60" with 1 1/2" of "wall" on each end.
    Sep 2006
    cold new york
    It looks like the tub is 53-54". I hope they're still available.
    Gore Vidal.
    If it's not a 60" tub, then 54" is a possibility. But, unless you are bathing only a child or very short adult, that small of a tub might better be turned into a shower. Since 60" tubs are the 'norm' in the USA, any other size will have limited volume, fewer choices, and likely higher costs.
    I have to accept your measurement, but since you started out at 57" and a 54" tub would measure about 52" between the walls, I cannot be sure what you have. A 54" steel tub would be a VERY unusual animal.
    Sep 2006
    cold new york
    The first measurement of 57" was incorrect. The tub is in fact 53-54" (from edge to edge and not wall to wall). It is an old tub (60 years +) that is steel or cast iron. The local store told me that they have 53" tubs available for arouind $350.
    Gore Vidal.
    I have never heard of, nor seen, a "53 inch" tub so he must mean 54" unless it is some little known manufacturer.
  1. Looking for "short" tub filler
    By mmax in forum Shower & bathtub Forum & Blog
    Last Post: 07-26-2010, 12:15 PM
  2. 60" x 42" bathtubs with large base? (Replacing a tub-shower)
    By areacode514 in forum Shower & bathtub Forum & Blog
    Last Post: 08-17-2008, 08:46 PM
  3. 14+" rough -- only 41" to wall -- short toilets?
    By OriginalPlumbing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2008, 01:57 PM
  4. I need a short toilet -- only 41" of space
    By OriginalPlumbing in forum Toilet Forum discussions
    Last Post: 06-29-2008, 12:13 AM
  5. is a 3" short 90 OK in toilet drain?
    By sjb8112 in forum Toilet Forum discussions
    Last Post: 06-18-2005, 10:46 AM
