Thread: Cracked Tub
    DIY Junior Member OhioMike's Avatar
    Apr 2011
    Cincinnati, OH
    Default Cracked Tub
    While installing my overflow drain I cracked my acrylic tub. The crack is about 3/4" long up around the overflow hole. Is there any hope of fixing this? Would calling Kohler be a viable repair option?
    Thanks for any advice.
    Mike
    In the yellow pages you will find "tub refinish"
    http://www.dexknows.com/local/constr.../att/bathtubs/
    The washer that seals the overflow is often tapered to allow you to get it parallel with the wall of the tub. If it is not nice an straight, and you tighten things down too much, this could be why it cracked. Some drain systems have a flex joint that allow a flat washer.
  1. cracked tub
    By lati_cz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2009, 11:52 AM
  2. Cracked CI stack
    By momisana in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2009, 07:06 AM
  3. Cracked Urinal
    By maintenanceguy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-02-2008, 04:45 PM
  4. Bad / Cracked Toilet???
    By steveg91 in forum Toilet Forum discussions
    Last Post: 12-26-2007, 10:11 AM
  5. Cracked toilet?
    By Peterson in forum Toilet Forum discussions
    Last Post: 09-08-2007, 05:07 PM
