Thread: Basement Shower Install
    DIY Junior Member dennis51's Avatar
    Apr 2011
    South Saint Paul Minnesota
    Default Basement Shower Install
    Hello,
    I am putting in a bathroom in my basement. On the cold wall I put 2 inch pink styrofoam insulation from corning and I then framed a wall over that. the shower is going in the corner where one wall will be next to the pink stuff and the other wall will be against a dry/warm wall. Is the pink stuff good for a vapor barrier against the cold wall, and do I need to put a vapor barrier where the warm wall is? I am going to use Durock Cement Board for the walls.
    I appreciate any suggestions
    Dennis
    Jan 2008
    The "pink stuff" is extruded foam, and acts as a vapor retarder. Because of it's fire and smoke spread characteristics, it must be covered with a 15 minute thermal barrier when used indoors. Drywall is the only approved barrier I am aware of, though there might be others.
    nitin parashar
    Guest
    Default Shower Pod
    Shower must be fitted to the cold side of the tap and you must use a small and handy shower which can be easily fitted and don't create any problem to get fitted and it will fit in small space also.
    __________
    shower pod
  1. Replies: 3
    Last Post: 03-08-2010, 05:52 PM
  2. Uneven basement floor, how to install shower?
    By Bosun in forum Shower & bathtub Forum & Blog
    Last Post: 09-11-2007, 03:08 PM
  3. Basement Shower Install
    By rblystone in forum Shower & bathtub Forum & Blog
    Last Post: 12-19-2006, 03:44 AM
  4. New Install In Basement
    By fletchfb in forum Toilet Forum discussions
    Last Post: 12-28-2005, 01:39 PM
  5. Shower tub install in basement
    By Pennwd in forum Shower & bathtub Forum & Blog
    Last Post: 06-23-2005, 04:25 AM
