Results 1 to 9 of 9
Thread: Water Results, Filter Recommendations?
    DIY Junior Member bewing's Avatar
    Aug 2010
    Arkansas
    Default Water Results, Filter Recommendations?
    Hello, I had a well drilled back in November, and finally have gotten to the point of getting a pump set and sent off for a water test. The water test is back and I need some help understanding some of the numbers and getting some help with what type of filtration I need. Here is some of the information about the well.
    Drilled Depth - 165 ft.
    Hit water at - 135 ft.
    Static Water level - 80 ft.
    Diameter - 6" rock bore
    recovery rate - 10gpm
    Pump - 3/4 hp 12 gpm pump
    Now for the test results (All results reported in mg/l unless otherwise indicated
    pH - 6.82
    Dissolved Solids - 148
    Arsenic - <0.05
    Harness - 48
    Iron - 1.00
    Manganese - 0.101
    Nitrogen, Nitrate - .260
    Sulfates - 13
    Turbidity - 22 FTU
    Total Coliform - 6 Colonies/100ml
    I don't know much about any of those numbers except that the Total Coliform scares me. The well has never been shocked, the driller didn't shock the well back in November when it was drilled, and it was never shocked after the pump was set about a month ago. Is shocking it the right thing to do and re-test. Or should I get some filtration to take care of the bacteria?
    Barret
    Dec 2009
    Alaska
    I would go ahead and shock the well, possible that some thing got in there at the start of between the start and now.
    recovery at 10gpm and the pump is 12pgm?
    Aug 2010
    Arkansas
    Quote Originally Posted by Akpsdvan View Post
    The pump is a 12 gpm, but only when the static water level is very high. At my static water level the pump produces just under 10gpm.
    Are there any recommendations for an iron filter that I have enough gpm to back flush?
    Since the water is not hard I'd like to not use a softener if possible.
    Dec 2009
    Alaska
    You have the flow rate for greensand filter.. I would size it for 10gpm and not the 12 that the pump can do.
    I would stay away from any unit that pulls in air to oxidize the iron and Mn... there will be lots of cleaning needed to keep the unit running long term.
    Aug 2010
    Arkansas
    Thanks for the help. Is there anyway I could run a pyrolox or filox filter with my flow rates? And is there any advantage to those over greensand?
    How did you measure 10 gpm from the pump? Unless it was through a 1" ID pipe, you'll read low.
    Aug 2010
    Arkansas
    It was measured through 1.25" ID, with no back pressure basically except through one 90 degree elbow. I don't have any equipment hooked up yet still trying to figure out the filter stuff before hooking pressure tank up.
    HydroFLOW protect wells from limescale using radio waves in an electric field. they have sizes for all diameters of pipe.
    HydroFLOW uses natural osmosis to combat bacteria. It could be all you need.
    I wouldn't use a salt based softener, as they need maintenance and you can't drink the water.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by PeterMiles View Post
    That's real strange. I've been drinking salt based soft water for, let's see, at least 20 years now. What makes you say you can't drink the water from salt based softener?
  1. Whole house water filter recommendations?
    By rldev in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-20-2011, 09:34 AM
  2. Well Water test results. Recommendations?
    By novas in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-23-2011, 10:57 AM
  3. Whole house filter recommendations for colored well water ?
    By riverside67 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-06-2010, 06:09 AM
  4. Recommendations for high flow pre- and post- filter cansisters?
    By scorpionleather in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-28-2009, 06:09 PM
  5. Well water test results
    By WV Hillbilly in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-03-2008, 01:10 PM
