Results 1 to 6 of 6
Thread: Can remote electric meter reading cause circuit breakers to trip?
    DIY Junior Member njghost's Avatar
    Apr 2011
    Teaneck, NJ
    Default Can remote electric meter reading cause circuit breakers to trip?
    The other day, the meter reader came to read our meter, and used some contraption that made a weird noise - I'm always right there when he reads it, and it was definitely something new. He said it sends the reading remotely (or something).
    A few hours later, we're suddenly tripping circuit breakers right and left! We haven't tripped a breaker in YEARS. PSE&G, our provider says there's no way what their employee did could have caused our breakers to suddenly start tripping.
    Are they right? Was this just a coincidence? And if the latter, what do we do?
    Thanks.
    Jun 2007
    North Carolina
    What they did would have no effect on your breakers. Maybe you should call an electrician
    Mar 2011
    Houston, TX
    Hello Group,
    If You don't pay your bill they can shut your power Off. Not sure if a breaker would blow, That don't sound right, Ground Fault Might.
    They can also shut your car off if you don't pay your car payment.
    Technology is nice, But don't be fooled that it is good for You.
    In our area people have been getting BIG electric Bills, They can also be hacked, They are wireless.
    I like OLD school...
    Tell me what You think, about remote meter reading... And Remote Control...
    Just a thought from DonL...
    Have a good one.
    Thank You Terry Love, Your Forums are Great.
    The only things that can trip a circuit breaker are a short circuit, or an overload, or heat buildup from a loose connection, none of which have anything to do with the meter.
    Mar 2011
    Houston, TX
    Good Morning hj and the group.
    A Ground Fault Circuit Breaker, Senses hot wire-to-ground faults , and shuts off.
    So it depends on what type of breaker it is.
    I agree that the Meter has nothing to do with the breaker getting tripped. (Other than supplying the Power to trip it)
    Have a Great Day.
    DonL.
    Well, Don, the GFCI actually measures the difference in the current between the hot and the neutral...it doesn't even need a ground to work. If the current returning isn't within a very small amount (often around 5ma), it trips. That lost current could go to the ground circuit, or anywhere, but it's irrelevant if the ground is actually there.
  1. Two GFCI Breakers in one circuit?
    By jmartin in forum Electrical Forum discussion & Blog
    Last Post: 04-07-2010, 04:00 PM
  2. Short Circuit but Breaker does not trip
    By vino82 in forum Electrical Forum discussion & Blog
    Last Post: 01-29-2010, 11:51 AM
  3. Arc fault circuit breakers
    By chukakid in forum Electrical Forum discussion & Blog
    Last Post: 05-01-2009, 09:03 AM
  4. common trip breakers
    By puckhead95 in forum Electrical Forum discussion & Blog
    Last Post: 01-20-2009, 10:28 AM
  5. Submersible pump drops circuit breakers
    By tinytec in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2006, 05:38 AM
