Thread: Bathtub/Shower Valve distance to Tub Spout
    Mar 2011
    Long Island, NY
    Default Bathtub/Shower Valve distance to Tub Spout
    Hi,
    I recently bought a new Delta Intuition bathtub and shower valve package complete with the tub spout and shower head. The installation instructions say that the distance from the bottom of the valve body to the tub spout should be 8 to 18 inches. I am using this new setup to replace an older Delta valve body installation where the tub spout is slightly less (about 5 inches) below the valve body.
    I was just curious why they would spec out the distance other than just for the convenience of having
    the tub spout and valve body in "comfortable" positions. The tub spout seems at the correct height above the tub, and the valve is easy to reach as it is whether taking a shower or bathing.
    They err on the conservative side so the spout and valve trim plate do not interfere with each other.
    The same valve supports many different trims...so, as mentioned, to ensure any one will fit, they define a minimum separation.
    Mar 2011
    Long Island, NY
    Thank you gentlemen
  1. Squealing Moen Tub Spout or Shower Valve
    By davidhmd in forum Plumbing Forum Discussion & Blog
    Last Post: 04-20-2011, 11:13 AM
  2. New tub/shower trim and valve...now tub spout only drips...
    By jsarin1 in forum Shower & bathtub Forum & Blog
    Last Post: 11-26-2010, 01:47 PM
  3. Shower Diverter on Valve Trim or Spout?
    By pmetiv in forum Shower & bathtub Forum & Blog
    Last Post: 10-17-2008, 03:19 PM
  4. Distance between valve and spout
    By Fastclient in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2008, 01:06 PM
  5. shower valve causing leak through tub spout
    By onedayatatime in forum Shower & bathtub Forum & Blog
    Last Post: 09-22-2006, 09:54 AM
