Results 1 to 5 of 5
Thread: Can't get aerator out of a Kohler
    DIY Member jed1154's Avatar
    Feb 2008
    Texas
    Default Can't get aerator out of a Kohler
    I have no clue what kind of faucet it is, but its in the bathroom and looks similar to the Fairfax. It has an aerator inside and it needs to be cleaned, but its not like my others. It doesnt seem to have a 'thing' that threads off or it revealing the aerator. The aerator is inside and there looks like a ring on the outside, but it does not turn. Is it pressed in? Does it require a special tool?
    It would NOT "press in", but it could require a special tool. If we could see it, or a good picture, we might be able to help you.
    Plumber jimbo's Avatar
    If it is a Farifax see this diagram ( lav is similar) http://www.kohlerserviceparts.kohler...6981289ba9d461
    The large flange or escutcheon at the mouth of the faucet unscrews. Should just be hand tight, but might need a strap wrench.
    Feb 2008
    Texas
    OK, so that 79402 unscrews...wow.
    Its going to require a small strap wrench then. Its far more than hand tight. I can't unthread it with both hands clenched on it. Ill try again later.
    Thanks for the info. At least I know its supposed to unscrew and not snap off somehow.
    quote; At least I know its supposed to unscrew and not snap off somehow.
    It is SUPPOSED to unscrew, but it COULD snap off, (or need to be snapped off), if it is corroded into the spout.
  1. Well Aerator will not come on when water is tank is low.
    By RobertPod in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-18-2012, 07:51 AM
  2. aerator tank
    By jtoboll in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2011, 07:24 AM
  3. please identify aerator
    By dk518 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2010, 07:42 PM
  4. Broadway Aerator
    By mike802 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-24-2008, 03:47 AM
  5. Aerator Spraying
    By bdp68 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-02-2006, 08:49 AM
