Why is there a need to get back into the programing mode?
I recently installed a Fleck 5600SXT and went through all the programing, but now I can't get back to all the info that I could previously? When I go into the setting mode it only gives me the options to set DO, RT, Hardness, and the percentage safety. Just trying to figure out what I am doing wrong? Thanks
Well, when I first hooked it up I set my "C" to 32 because I bought a 32000 grain system but then read some where else that it should be set to 20 for the "Salt Efficiency Method"? So I am thinking I should not have changed the settings initially? thanks
When you bought the unit did it come with this book?
http://www.pentairwatertreatment.com...al%2042713.pdf
How about you give me a fish this time and not try to teach me how to fish. I have the manual but I need to know which reset I should use?
Water test?
Number of people in the house?
You can either use gallons or a % of the capacity as the reserve.
I use the gallons, -X based on number of people in the home.
Some use 60 gallons per person per day others use 75 gallons per day per person.
