Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: TOTO elongated dual-flush ONE PIECE Aquia - NEW MS654204MF
    DIY Junior Member baby_mama's Avatar
    Apr 2011
    Vineland, NJ
    Default TOTO elongated dual-flush ONE PIECE Aquia - NEW MS654204MF
    I went to the TOTO website & found they are introducing the Aquia ONE PIECE dual flush toilet. It only comes in Universal height & unlike the Aquia III, it comes in all of their colors. I called my local store & they didn't know about it, but did see in their books it is coming out 2nd quarter this year - which is now. They will be calling their suppliers on Monday. I was told it goes for $600 in white. Does anyone have any reviews for this toilet, yet?
    http://www.totousa.com/ProductDetail...d-0c257ded6f53
    Last edited by Terry; 04-09-2011 at 10:43 AM. Reason: correction in spelling of aquia
    This list price in white is $750.00 which translates with discount to a Seattle area price of $525.00
    It looks pretty similar to the other Aquia bowls, except for the tank being molded to the bowl. That should make for a nice installation.
    I expect performance to be like the others based on the spec sheet.
    Apr 2011
    Vineland, NJ
    I called my supply house in South Jersey & was told the price would be $600 - and that's the contractor's price. I was also told that he called around and found this toilet will not be available on the market until late June/early July.
    Apr 2011
    Vineland, NJ
    Oh, please excuse my poor manners! I wanted to let you know that I really appreciate your feedback, Terry.
    $600 would still be a good price. It's just that I have "Killer" pricing for my Seattle customers. Thanks for the update on when it will be available.
    Default TOTO Aquia One-Piece Toilet, Dual Flush, Pictures and reviews, MS654204MF
    Standard 12" Rough
    Watersense, with either 1.6 GPF or 0.90 GPF
    Comes with SS204 Softclose seat.
    16-1/8" Universal Height, Elongated bowl.
    With the seat it becomes an ADA toilet.
    28-0" long
    I now have this in the Seattle area
    Toto in Seattle
    This toilet was installed with a less then 12" rough.
    Notice the room behind for the shutoff valve.
    This Aquia was made in the USA.
    With the SS204 seat down
    With the SS204 seat open
    DIY Junior Member Chris Cullen's Avatar
    Oct 2011
    NJ
    Default Aquia one piece specs
    Hi Terry
    Thanks for this excellent resource, I stumbled across the forum a couple of days ago and am grateful for all useful Q & A.
    Speaking of which, I'm pretty much sold on Aquia, but I wonder if you can answer a couple of questions. The one-piece specs list the following:
    Water Surface 5-1/4" x 4-1/4"
    Trap Diameter 1-3/4"
    Trap Seal 2-1/4"
    -These are smaller than the specs for the Aquia III 2-piece. Any thoughts about that? potential issues?
    -Also the spec sheet lists length at 28", but I see in one of your posts you had it at 27 1/4". I'm replacing the toilet in a tiny powder room, so I'm hoping your measurements are correct.
    -The rough in is 11 5/8" to the center of the existing bolts, and the toilet will out of necessity be shimmed to pitch away from the wall, so I ought to be okay. Seems to me that the 1-piece might do better in the event there contact with the wall as there is no tank/toilet seal to compromise. Does that sound right, or am I asking for trouble?
    Thanks in advance for any replies, I really appreciate the help.
    -Chris
    I just looked at the spec again and it looks to be 28" long with about 3/4" behind the tank on a 12" rough.
    Oct 2011
    NJ
    Hi. Thanks for the quick reply, those measurements are encouraging. Does the 1-3/4" trap diameter on the 1-piece present any issues? The 2-piece lists at 2-1/8". Thanks!
    DIY Junior Member KingJerky's Avatar
    Mar 2012
    Michigan
    Default Any issues or complaints on MS654204MF from the "field"?
    Hello Terry,
    This is my first post and I'd like to say that I have made excellent use of your forum and recommendations. I very much appreciate your time and dedication to providing consumers with this information. I have been replacing the old Mansfield toilets in my home as I remodel each bathroom. I have a Toto UltraMax II/Gwyneth one piece now and am very pleased with it, but this one has caught my eye based on the dual flush technology and the skirted appearance at this price point.
    My concern is the water spot size in this model. One of the photos you posted in this thread with the lid open looking down into the bowl would seem to show a very small water spot. My concern is 'skid marks' and the bowl rinse to remove them... I have read a few complaints about this issue on your forum with the Aquia line. I'd like to make an informed decision and would like your professional opinion...
    Is this an issue? Is it enough of an issue that you'd recommend that I go with a Toto Carlyle II one piece instead? I am going to assume the issue doesn't exist in the Carlyle II so that may be an error on my part. I can get the Aquia III at a lower price point and it saves water, but that isn't worth it to me if I have to brush it.
    I am being quoted the following by my local Plumbing Supply store in town:
    Aquia III (MS564204MF01) : $557 + tax (6% here)
    Carlyle II (MS614114CEFG) : $607 + tax
    Ultramax II (MS60411CEFG): $492 + tax
    Hopefully those are good prices as that shop is up the road and I like to support local business as long as they are competitive. I look forward to your reply.
    Thanks in advance!!
    -Don
    Because a dual-flush wants to empty the bowl, regardless of which button you press, the bowl volume must be smaller than with a single flush design. Otherwise, you'd be leaving behind some waste when you flush. As a result, since you want some depth to cover things during use, the surface area is smaller. For the area to be the same, it has to be shallower, and to many, that is more objectionable. Skid marks are very much dependent on diet and aim...most Toto seats are uncomfortable unless you plant your butt over the water spot which helps unless it is an explosive discharge!
    Mar 2012
    Michigan
    LOL - thanks for your comments. I found answers to many of my questions/concerns just searching the forum too. Learning my way around...
    DIY Junior Member dayooper951's Avatar
    Feb 2011
    SE Michigan
    The water spot seems fine and with the Sanagloss skidders aren't much of an issue.
    DIY Junior Member vans's Avatar
    May 2007
    Florida
    I am a Maintenace Manager for a Foundation, we have over 30 buidings
    I have 8 of these CST464MF Aquia Dual Flush ADA in a new LEED Certified Building
    No Problems so far, Toto toilets Rock, I bet I have 20 of the Drakes and never have any issues
    Today I ran acrost a problem that I hope someone has a better answer than I
    Loose Toilet Seat- it looks like I have to pull stool to tighten-any tricks or idea
  1. Toto Aquia II Dual Flush leaking - help!
    By tototoo in forum Toilet Forum discussions
    Last Post: 08-17-2008, 10:48 AM
  2. AS Flowise Dual Flush = Toto Aquia???
    By Scorponox in forum Toilet Forum discussions
    Last Post: 03-25-2008, 10:01 AM
  3. Toto Aquia verses Caroma dual flush
    By acb in forum Toilet Forum discussions
    Last Post: 02-01-2008, 06:47 PM
  4. Non-Pro Advice on Dual Flush Toto Aquia
    By Mike50 in forum Toilet Forum discussions
    Last Post: 10-29-2006, 09:21 AM
  5. Toto Aquia Dual Flush - bowl doesn't empty completely
    By hmac in forum Toilet Forum discussions
    Last Post: 12-31-2005, 12:25 PM
