Results 1 to 2 of 2
Thread: Shallow Well
    Questions from readers Guest's Avatar
    posts, emails and comments from readers reposted by Terry
    Default Shallow Well
    I installed the well forty years ago and it has worked well until the last of 2010. The pump is a Sears 390-4100 model.
    Now it will pump a reasonable flow for awhile then change to a dribble. Is this a problem that could be in the pump? Or is the likely reason water supply is drying up? I have back flushed it several times and the water goes right through it.
    I wouldn't mind replacing the thing if I knew I still had water.
    BTW, the pipes go down about fifty ft or lower. The pipe is 1 1/4".
    Thanks for your help in advance.
    Stumpoak
    Jan 2008
    Virginia Beach, VA
    Most driven wells last from 20 to 40 years. It could be a hole in the suction pipe below the water line but I doubt it. It's not the pump.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Shallow Well
    By ciws14 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-09-2009, 11:07 AM
  2. Shallow well HELP!!! Is it going dry??
    By jazzie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-20-2009, 09:54 PM
  3. Shallow well
    By Byron1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-21-2007, 07:39 AM
  4. Shallow Well
    By Hank in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-25-2007, 05:49 AM
  5. shallow well ?
    By nimrod in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-15-2007, 04:54 PM
