Thread: pex rings
    DIY Senior Member rockycmt's Avatar
    Nov 2007
    New York
    Default pex rings
    I am interested in doing some pex plumbing and want to invest in a good tool. I see there are two types. Compression ring (Tool goes around the entire ring and compresses it.) and crimp ring (Tool crimps one side of the ring and compresses it.) Which is Better? I also do not want to get a tool that only works with hard to find fittings.
    Any comments?
    Chris
    Well, actually, there is a third type that expands the tubing so you can then insert a fitting. Then, the tubing memory squeezes itself down onto the fitting by itself. Because you expand it, the fitting has less restrictions since it is larger.
    DIY Junior Member BenWara's Avatar
    Oct 2010
    sd
    this probbly won't be to helpful but my house was plumbed withh pex and they used the crimp type. I've added a few fixtures so naturally just went with that type. The only problem I have is if you have to take the band off. they sell a tool that cuts the compression ring off so you can reuse fitting but haven't seen a tool to remove the other type. I end up just using a hacksaw to cut the crimp off which is kind of a pain sometimes. maybe i just need bigger cutting pliers? other than that the crimp type is working good for me. The tool i purchased to crimp the ring is by apollo and was less than $40.
  1. Which is better ?Wax Toilet Rings vs Wax-free Toilet Rings
    By herbolaryo in forum Toilet Forum discussions
    Last Post: 05-31-2007, 12:06 PM
  2. wax rings
    By tonyhd1 in forum Toilet Forum discussions
    Last Post: 03-21-2007, 05:35 AM
  3. wax rings
    By joust13 in forum Toilet Forum discussions
    Last Post: 04-24-2006, 06:46 PM
  4. Wax Rings?
    By Beerman in forum Toilet Forum discussions
    Last Post: 04-01-2006, 11:57 AM
  5. How many wax rings?
    By Netty in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-02-2005, 05:59 PM
