Thread: Hose bib wiggles : how to fix ?
    DIY Junior Member Rime's Avatar
    Oct 2010
    California
    Default Hose bib wiggles : how to fix ?
    One of my outside hose bibs wiggles whenever I press on it ( yes, I know, I shouldn't do that ! ) or when I'm attaching the hose or moving the hose about. I have visions of the wiggle stressing the pipe it's attached to, breaking a soldered connection, and creating my very own private waterfall ( in the wall where I can't enjoy it :-( ) Is there anything I can do to stabilize the bib ? It's just a piece of copper pipe sticking out of the wall with the hose bib soldered on.
    Thanks !
    You're not going to break the solder connection, but you could bend the pipe. There should be a collar on the hose bib that has holes or slots for screws that would anchor the bib to the side of the house. If this is not what you have, you might go inside the house and fasten a clamp that would hold the bib tight against the house. A clamp that is normally used to attach a ground wire to a pipe would work. I'm not sure of the proper name for it, probably something like "grounding clamp" would give a clerk a clue.
    The TYPE of "hose bibb" you have and its connection would determine how we would answer your question, so a picture would be very helpful.
  1. A Quality Hose Bib
    By RobertM in forum Plumbing Forum Discussion & Blog
    Last Post: 06-01-2010, 11:37 AM
  2. Air Gap Hose
    By kornbln in forum Plumbing Forum Discussion & Blog
    Last Post: 10-29-2008, 06:54 AM
  3. Air hose reel used as garden hose reel???
    By Montalvo in forum Plumbing Forum Discussion & Blog
    Last Post: 05-18-2008, 07:38 PM
  4. hose bib
    By cwhyu2 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-05-2008, 03:40 PM
  5. Hose to valve. Solid pipe or hose, which is better?
    By bnbhoha in forum Toilet Forum discussions
    Last Post: 12-19-2005, 07:36 AM
