I would check the ground wire very carefully. The ground wire is linked from the controller to each solenoid and the connectors are either special waterproof wire nuts or regular wire nuts with silicone. It sounds like the connection is broken prior to the first solenoid since none of them work. If part of them work, then the connection is broken after the last working one.
