Thread: Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order?
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order?
    Have gutted a small 650 small up north (Michigan) cabin and am replumbing it all. Just a small sediment filter there originally and water heater which i removed as they were old.
    Galvanized coming in and will go to copper. dielectric union, 6" brass pipe?? What is the best order...water line to sediment filter, where does expansion tank connect and how, then water soft (any good makes suggest for sed filter and softener) then to water heater and out. also is it a good idea to run a hose bib for watering lawn before the filter? Please advise and thanks a lot!
    Probably a silly question but have not noticed any kind of jumper cable for electrical grounding along water well line - not grounded i guess like a city line thru basement cement and water meters. did see a stake near the electric panel. guessing that grounds the elctrical system. thanks for the advice.
    DIY Member jed1154's Avatar
    Feb 2008
    Texas
    I am not a plumber, but the way mine is set up is that the sediment filter (A vuflow, I think) is installed AFTER the pressure tank. I was specifically instructed to never install anything between the well and tank. So, its filtered there before going into the softener and into the house. I leave my 'outside' water unfiltered.
    My filter catches all sorts of sand.
    Jan 2011
    levering, michigan
    thanks. have heard that a "t" is often used from the well source, with one side of the "t' going to the exspansion tank and the other toward the sediment filter. does that sound problematic?
  1. well water sediment filter question
    By bronzemaxell in forum Plumbing Forum Discussion & Blog
    Last Post: 07-27-2010, 06:24 AM
  2. Black sediment coming from Water Softener
    By accord91 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-20-2010, 12:30 PM
  3. Recommend Water Filter (not softener)
    By Oldcoyote in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-01-2009, 06:13 PM
  4. New water heater, existing water softener, expansion tank needed?
    By dhancock in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2009, 08:09 PM
  5. Iron filter vs. water softener
    By rburt5 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-24-2008, 11:25 AM
