Results 1 to 9 of 9
Thread: Greenboard Okay For Tub Surround?
Hybrid View
    DIY Senior Member Briandl's Avatar
    Feb 2008
    Texas
    Default Greenboard Okay For Tub Surround?
    My understanding is that it's definitely not okay to use Greenboard for a tile backing. From what I've read it MIGHT be okay if everything is done just so and the grout sealed, but only a very small minority claim this, virtually everyone else says concrete type backerboard.
    My understanding also is that USG says the following:
    Panels are not intended for use in areas subject to constant moisture such as tub and shower enclosures
    Does this mean it should not be used as a backer for a glue up tub/shower surround?
    It's my understanding that greenboard was designed to be used in moisture areas like bathroom walls, but not specifically behind surrounds and/or tile.
    If it makes a difference this is the greenboard from about fifteen years ago, not the newer type.
    Current codes no longer allow greenboard in a tub surround or shower area. Not all areas use the latest codes. On a wet area, use cbu. While the covering is moisture resistant, the cut edges and screw holes pierce it, and the interior isn't much any better than regular drywall.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    To confirm -
    Green board is not allowed by code behind tile.
    That said when I was way younger I worked for a slum lord, and did lots of bathrooms with green board as a backing for tile.
    Using green board we were getting about ten years maximum useful life out of a bathroom remodel. Most were less than that, but these were bathrooms that I did way way back when I was in High School and thats what my father wanted, but then again he was a slum lord.
    Michael
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Briandl View Post
    There is a big difference between tile and a one, two, or three piece surround. Schluter claims you can use KERDI over drywall in a shower. A tub surround would seal as well as KERDI.
    That sais, I used DUROCK behind the KERDI in my shower. I've also installed a three piece tub surround over existing tile that was set on drywall.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    plastic/acrylic surrounds are non-porous, so drywall is fine so long as silicone seals are maintained. drywall around a drop-in tub is fine as the walls aren't going to be subjected to constant soaking. Drywall can be used in a shower space if an expensive sealing membrane is painted on and not trashed by a careless tiler. But if you intend on tiling, then a proper vapour barrier with either cbu/mud walls is the only way to go. Some people prefer to use the kerdi system, but IMO it's an overpriced and overhyped system targeted at the DIY crowd.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Feb 2008
    Texas
    What would you normally glue a glue up type wall surround to?
    I'm starting to lean towards Kerdi on top of the greenboard, it's my understanding that there is an exemption in the IRC that allows for this type of usage, I'd then tile over that.
    It was under the impression that just because something can create a physical barrier, that doesn't stop water vapor.
    Plumber jimbo's Avatar
    I don't know about that statement. The mistake that has been made in the past was to assume that a grouted tile surface was waterPROOF....which it is not. Glazed ceramic tile is impermeable, but grout is porous..
    Jul 2009
    North Vancouver, BC
    Post(s) deleted by John Whipple
    Greenboard, for the discussion here, I think, is moisture resistant drywall...
    This used to be suggested for use under tile in wet/damp areas, but is no longer approved for that purpose. Other products that may be green are not necessarily the same. In a shower area, unless it is covered by an approved waterproof membrane, you don't want to use drywall or greenboard. And, if you were going to use a waterproof membrane (or waterproof surround), then drywall would still work. Typical greenboard also isn't as stiff as drywall, so when used on a ceiling, generally calls for closer spacing of supports (i.e., 12" OC rather than 16" as used with typical drywall), or it can droop or bow.
  1. greenboard or cement board?
    By amys in forum Remodel Forum & Blog
    Last Post: 04-18-2012, 03:53 PM
  2. Tile over greenboard?
    By jhetzig in forum Shower & bathtub Forum & Blog
    Last Post: 08-29-2010, 11:28 AM
  3. Hardiebacker vs Greenboard
    By idoc4u in forum Shower & bathtub Forum & Blog
    Last Post: 03-16-2010, 05:30 PM
  4. proper use of greenboard
    By econguy in forum Remodel Forum & Blog
    Last Post: 04-21-2007, 05:17 AM
  5. greenboard and hardiboard issues
    By Bob Affleck in forum Shower & bathtub Forum & Blog
    Last Post: 04-24-2006, 08:24 AM
