Thread: shower temp mixing valve question
    DIY Junior Member novasupra's Avatar
    Apr 2011
    VA
    Default shower temp mixing valve question
    Hi, I have a Grohe shower set, has a rain shower head and also body spray. There is a control for the shower head and also a control for the body spray and a also a seperate control for the temperature.
    For some reason, the temperature valve does not "mix" the hot and cold water, I either get all hot or all cold but nothing in between. If I take the cover off and adjust the temperature setting, i can turn it to the point where it gets hot then if I back it off, it doesn't temper down it just stays hot and then all of a sudden it will go cold.
    Is there any other adjustment that I need to make?
    Appreciate the help.
    Take the cover plates off the valve take a picture of it and post it. Someone might be able to help you then.
    Your core must be sticking or has failed.
  1. Bad Sterling Mixing Valve in Shower
    By Tleast in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2011, 07:14 PM
  2. Replies: 3
    Last Post: 08-09-2010, 06:44 PM
  3. Need new shower/tub mixing valve
    By Scuba_Dave in forum Shower & bathtub Forum & Blog
    Last Post: 10-26-2009, 11:17 AM
  4. Need to replace Shower mixing valve with separate cutoff valve for inputs.
    By OfficeLinebacker in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 09:06 AM
  5. Pegasus mixing valve for shower.
    By canton in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2006, 04:22 PM
