Results 1 to 8 of 8
Thread: Extraction of submersible pump
    DIY Junior Member
    Apr 2011
    Mumbai
    Default Extraction of submersible pump
    Hi
    We have Dug a Boring hole uptill 500 ft below, we managed to release the submersible pump till 240 ft, unfortunately the Iron pipe broke and the Pump went rushing till the end.
    We would like to extract the submersible pump along with 20 no's * 20 ft pipe with the PUMP.
    Can you pls let us know different process or way to sucessfully extract the pump.
    Navin
    Moderator valveman's Avatar
    Mar 2006
    Where did the pipe break? Do you have a coupling on top or did the coupling break off which would leave only slick pipe to grab on to?
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    I once got 300' of 1" steel pipe out of a 1200' well with a taper tap and 900' of pipe
    http://www.gotco-usa.com/internal-catch/taper_tap.html
    Chris Kofer
    h2oguy.com
    In the "old days" they used a drive shaft from a model A which was hollow and tapered. They dropped it down the well and it slid over the pipe and usually "jammed" it so the pump came out when they retrieved it.
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    i've fished out alot of broke pipes with a taper tap and/or an "overshot" inside tapered fishing tool... though i've never done anything close to WWP at pullin 300' out of a 1200' hole.. kudos to you waterwellproducts, i bet that was a PITA to say the least.
    Mar 2006
    I have fished a lot of things, and it is always better to know what is sticking up at you. It is much easier to grab a couling than slick pipe. With a couling sticking up, I use to make an overshot out of pipe that would fit over the drop pipe. Then put two or three flat pieces of steel about 2' long and welded at the bottom, inside the overshot. When you slide this over a couling the top of the flat steel catches the coupling and out it comes. Sounds easy but sometimes its not.
    DIY Junior Member
    Apr 2011
    Mumbai
    Hi
    Yes the coupling broke & the pipe is only to grab on.
    We tried traditional way by dropping the Iron Hook with the rope tied, But due to weight the pump and Pipe the rope broke half way and again went down.
    Feb 2011
    NW Ontario, Canada
    Sounds like your situation went from bad to worse. Not only do you now have a bunch of pipe and a pump in the hole but now there is a length of rope and an iron hook down the hole as well. Unfortunately the rope and hook will probably impede your efforts.
    What size is the casing and what size is the pump?
  1. Need help with pump extraction
    By Voltz in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-24-2008, 09:41 AM
  2. Best air extraction for hydronic heat?
    By jadnashua in forum HVAC Heating & Cooling
    Last Post: 12-30-2007, 03:09 PM
  3. extraction of foot valve
    By flyintyler in forum Irrigation / Sprinkler Forum
    Last Post: 11-19-2007, 05:31 AM
  4. Submersible Pump
    By dgray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-10-2007, 11:42 AM
  5. Submersible Well Pump
    By Cap'n Marty in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2005, 05:44 AM
