Results 1 to 2 of 2
Thread: Intake vs. Discharge sizing (shallow well)
    DIY Junior Member dbolong's Avatar
    Mar 2011
    Kansas
    Default Intake vs. Discharge sizing (shallow well)
    I use my shallow well pump for irrigation only. Set at 40/20 psi. Intake is 1 inch pvc-discharge 3/4 inch pex to spigot.
    I have got it to where the pump will not turn off as long as I have 3 sprinklers minimum hooked up to it.
    However, when I do hook 3 sprinklers up to it, the pump keeps at about 35 psi but the sprinklers are not exactly super high volume. Acceptable, but could be better.
    Should I increase my intake to 1 1/4 or 1 1/2? Would this increase my volume to a point to where maybe I could use less sprinklers to keep the pump running? Or will I be limited to the 3/4 inch discharge (that I do not want to change.)
    I've learned a lot with this little project of mine and appreciate all the help!
    Moderator valveman's Avatar
    Mar 2006
    Try turing the pressure switch up to 30/50 and see if you can run only 2 sprinklers without cycling.
  1. Fresh Air Intake
    By PistonDog in forum HVAC Heating & Cooling
    Last Post: 09-09-2009, 03:38 PM
  2. Shallow Well Pump - Intake
    By John Vanderheyden in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-28-2009, 09:19 AM
  3. Air Intake Knob
    By ladyhomeowner in forum Shower & bathtub Forum & Blog
    Last Post: 06-21-2008, 01:26 PM
  4. Problem with intake leak on shallow well jet pump
    By mcmommy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-25-2007, 08:20 PM
  5. A/C intake question...
    By Pewterpower in forum Remodel Forum & Blog
    Last Post: 08-10-2006, 07:46 AM
