Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
Thread: Is my submersible pump nearly finished?
  1. #31
    Nov 2010
    Maine
    Carey, thank you for that post. It is probably the only honest answer that anyone anywhere has ever given about CSV's and their applications.
  2. #32
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    still a stretch to say a csv4.4 is better/equal to a sub with ~25gal drawdown tank in the home as far as cycling. seriously, how many people actually have a toilet with less than 1 gallon flush? how does 20-30 cycles from flushing outweigh 3-4 cycles per 2-3 people from showering? ..and anyone taking this kind of shower is having way too much fun in there.
    with csv, i think that little initial price difference in tanks from 4.4 to 20 is a small price to not worry about your pump running with every little bit of demand.. those cycles add up.
  3. #33
    Moderator valveman's Avatar
    Mar 2006
    Here is a chart from Amtrols “lab study” on the subject. This was done for just a house with no irrigation or heat pump. The longest draw of water was for 7 minutes at a time. So it gives a good representation of how many times the pump will cycle for just a house. Notice that without a CSV, the pump cycled 19 times per day. And with a CSV and 20 gallon tank, the cycling was cut in half to 10 cycles per day, which is good. Using a 4.4 gallon tank with the CSV only brings the cycles per day back up to 19, which is equal to a “properly sized tank” system.
    Notice the variable speed pump cycled almost three times as much. This shows that no matter the size of pressure tank used, with VFD control the pump still has to start for every water use event, which is not good.
    Also notice the last line I added. This is the real test for a CSV. As with an irrigation system or a heat pump that only uses half of the total output of the pump, the CSV would keep the pump running constant and there would only be 1 cycle per year. With a “properly sized tank” system, this would cause 960 cycles per day or 350,000 per year, which is really not good. This shows the CSV really shines when using small amounts of water for long periods of time. But this chart also shows that for just house use alone, the CSV and 4.4 gallon tank won’t cycle anymore than a so called “properly sized tank” system.
  4. #34
    DIY Junior Member danielrhall's Avatar
    Apr 2011
    Raymond, NH USA
    Quote Originally Posted by ballvalve View Post
    Prior to a pull checking the amp draw on each wire would be very telling.
    Should be around 6 if its 240V
    It is 240V and 2-wire.
    I have the current draw measurements. Each of the two wires measures pretty much the same. When the pump starts, AC current is just under 20A and drops to just under 16A by the time cut-off pressure is reached. Yikes!
    I'm on borrowed time with that pump.
  5. #35
    May 2010
    NE FL, SE GA
    valveman, that was some good info. thanks.
  6. #36
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    Quote Originally Posted by danielrhall View Post
    If you run it long enough the overload should make it drop out to zero. You don't have too many gallons left on that pump....
    Chris Kofer
    h2oguy.com
  7. #37
    Apr 2011
    Raymond, NH USA
    I sent much of the following directly to Cary at CSV but would value responses from others. And I apologize in advance for the length, but I want to supply all possible relevant information.
    So I know I have to replace my submersible pump and would like to take the opportunity to make some upgrades and improvements in my well system. Hereís what Iíve got:
    Existing pump: Goulds 5GS05422, 1/2HP 5GPM 2-wire 230V. Installed in May 2004.
    Pressure tank: Well-X-Trol WX-202
    Pressure switch: set to 30/50 but would like to change to 40/60.
    Well: six-inch, pump at 260í, depth of well approximately 300í, static water level is 23í below pressure tank, 1Ē poly pipe from pump to pressure tank is 65í from tank to pitless adapter. Well yield is unknown but a neighbor thinks he remembers it being 7-8 GPM when it was drilled in 1977. If this helps, I have run two sprinkler head for over 12 hours constant many times in the summer without running out of water.
    As has been noted earlier in this topic, the existing pump definitely needs to be replaced since, during demand for volume, such as filling the washer, the pump has started to thermally cut-out. I measured it to be drawing 19 amps when it starts, so itís definitely almost finished. In spite of that, it will still make 60 PSI at the tank if I set it that way.
    Thereís something going on with the pressure tank that I donít quite understand. Its rated drawdown at 30/50 PSI is 6.8 gallons. But when I measure the drawdown from a nearby faucet, from when the pressure gauge reads 50 PSI down to 30 PSI and the pump turns on, Iím getting about 2.8 gallons. I donít quite understand that. I've set the tank pressure to 28 PSI when it's empty of water, it holds that pressure, and rocking the tank when empty certainly makes it seem to be empty, so the tank seems to be okay.
    After drawing down the 2.8 gallons and the pump cutting in, it then takes about 28 seconds to get the system back to 50 PSI, so Iím figuring that a) the pump is making about 6 GPM, and b) the pump is not running long enough to cool itself, which is probably a good reason why itís failing.
    So Iíd like to consider upgrading the pump to one that would provide me with more GPM for watering in the summer, since I do notice reduced volume when two sprinklers are running. A more constant and higher pressure would be nice too, since if I run two impact sprinklers, thereís not enough pressure or volume Ė not sure which Ė to get them to change their direction until the pump re-pressurizes the system.
    So thatís where the CSV comes in. I was originally considering the CSV150 and putting it in the well casing below the pitless adapter. I think my reason for choosing that valve is because, while Iíve tried to understand friction loss and reduced pressure falloff, Iím afraid Iím still not getting it. What I have understood is that the CSV1 less ďadverselyĒ affects system pressure or flow. But Iíd really like the convenience of being able to adjust the valve easily, and the durability of a brass valve, so Iíd like to consider either the CSV1Z or the CSV1W mounted in the house. From what Iíve described about my system, will the CSV1Z or CSV1W work well with my system? If not, since Iím considering upgrading components (particularly the pump), what would need to change?
    My understanding about the function of the CSV indicates that it will allow only 1 GPM above its pressure rating when thereís no more demand for water. Will that lengthen the refill time of my pressure tank and thus the on-time of my pump? Should I consider a larger pressure tank even with a CSV, for interior non-watering use, since Iím only getting 2.8 gallons of drawdown?
    Thanks in advance for any help anyone can offer.
  8. #38
    Jan 2008
    Virginia Beach, VA
    Valveman said it all. Pumps may last longer than 7 years but they have just so many cycles in them. In any case the pump has to come out of the well. I'd change the wire also or at least reverse the ends.
    I highly recommend installing a CSV or a Pside-Kick kit. A CSV will prevent cycling and give you a constant pressure while extending the life of your whole system.
    What ever you do, don't let anyone sell you a computerized CFD pump! They are expensive, troublesome and you think you have troubles now!!!
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  9. #39
    Mar 2006
    2.8 gallons of draw is more than you need with a CSV. But that tank should have 5-6 gallons of draw, so I think the tank is bad, and you won’t even have 2.8 gallons for very long. It is better to have a good 4.4 gallon tank with 1 gallon of draw, than to have that tank with a bad bladder that will waterlog completely fairly soon. If your pump still cycles on and off with the largest water zone being used, friction loss of any CSV will not be noticed.
  10. #40
    Apr 2011
    Raymond, NH USA
    2.8 gallons of draw is more than you need with a CSV. But that tank should have 5-6 gallons of draw, so I think the tank is bad, and you wonít even have 2.8 gallons for very long. It is better to have a good 4.4 gallon tank with 1 gallon of draw, than to have that tank with a bad bladder that will waterlog completely fairly soon. If your pump still cycles on and off with the largest water zone being used, friction loss of any CSV will not be noticed.
    Cary, thanks for the reply and the response to my email. I haven't had a chance to respond to the email yet, but I will add a little info here.
    The problem wasn't with the tank but with the water pressure gauge. It was actually a brand new gauge but it was reading 10 PSI too low. That made troubleshooting tougher, that's for sure. Things just weren't making sense. So after verifying that the air pressure in the tank was correct with two separate gauges, I determined that the water pressure gauge had to be bad. I put a new new water pressure gauge on the manifold, and now at about 35-55 PSI, that tank draws 6.2 gallons as it should.
    Because the bad gauge fooled me into setting the pressure switch incorrectly, the system was actually working at 48-68 PSI. The pump still cuts out thermally and needs to be replaced, but I'm impressed that the tired old girl will still make 68 PSI.
    -Dan
  1. SUBMERSIBLE PUMP 110 or 220
    By loudhornsrule in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-23-2010, 10:18 PM
  2. new submersible pump for well
    By tula-dan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2010, 04:07 PM
  3. Submersible pump going bad?
    By psyclemania in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-07-2009, 11:56 AM
  4. submersible pump
    By jim hay in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-27-2007, 10:15 AM
  5. Submersible Well Pump
    By Cap'n Marty in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2005, 05:44 AM
