Results 1 to 5 of 5
Thread: How to remove Grohe Sinfonia Faucet
    DIY Junior Member atulc's Avatar
    Mar 2011
    Metro NYC
    Default How to remove Grohe Sinfonia Faucet
    I need to replace the cartridge in my Grohe 20.655 Sinfonia two-handle lavatory wideset. This requires removal of the cross handle 1 and cap 5 (see the diagram and parts list). It is straight forward to remove the cross handle. But I can't figure out how to remove the cap.
    Grohe tech support recommended a strap wrench. I've tried, but the strap wrench keeps slipping because of the bell shape of the cap. As a last resort, I'd have to loosen the nut under the sink. But it is very crowded under the sink and I want to avoid this route. Any suggestions on how to unscrew the cap? Thanks.
Size:  9.1 KBName:  Parts.jpg
    Wrap it with black electrical tape and use a good pair of Channelock pliers. Removing the faucet would not help at all.
    Mar 2011
    Metro NYC
    HJ - thanks, I'll try out the electrical tape and channel lock pliers.
    Sorry, I didn't mean to remove the faucet but just the handle and cap. Thanks for correcting that.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Man I hate Grohe, heh. That escutcheon should unscrew. Hj's method will certainly give you a good grip, but you have to careful with how much squeezing force you apply. Another way to go is to wear gloves with a special rubber grip coating applied to the underside...that will allow your fingers to get a good grip if you can't get a rubber strap wrench on there.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Mar 2011
    Metro NYC
    Finally got the cap off by wrapping it in plenty of electrical tape and using channel lock pliers. I can see now why it was so hard to unscrew - the cartridge and the inside of the cap are heavily corroded. Now to the next challenge - despite removing the cap, I can't get the cartridge out. It's frozen inside the housing due to corrosion. Time to call Grohe for more warranty parts.
    Basement_lurker - agree with your sentiment.
  1. Grohe faucet install
    By Bosun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-25-2010, 07:53 PM
  2. Grohe Bridgford Faucet
    By Nettie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2010, 03:24 PM
  3. remove cartridge from Grohe model 33619
    By rjgogo in forum Shower & bathtub Forum & Blog
    Last Post: 11-25-2009, 04:52 PM
  4. grohe kitchen faucet
    By mrhdk2001 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2005, 12:07 PM
  5. GROHE Faucet Thread?
    By Damon578 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-27-2005, 06:35 PM
