Hi all.
see picture attached of the installation of the cartridge. From other pictures I've seen here that is right.
My problem is fitting together the key stop/limit stop/handle adapter properly.
basically, just using the handle adapter it starts at 6 o'clock being off, going clockwise starts cold and moves to warm hot, stops when you get back to 6 o'clock
However, using any combination of they key stop/temperature stop, the handle adapter, no matter where I orient things, will not do a proper rotation starting at off, rotating clockwise through cold to hot. It gets caught on the top notch of the stop tube key stop...its as if I am missing a piece that holds the keystop far enough out or something?
thanks so much.
thanks so much.
