Results 1 to 8 of 8
Thread: retaining wall
    DIY Junior Member BenWara's Avatar
    Oct 2010
    sd
    Default retaining wall
    I want to put a two tier retaining wall behind my house to lessen the slop of my yard. I have a split lever house with the lower level half underground. I know the footings have to be 4' under ground so they are below the frost line. I assume my footings aren't much deeper than that.
    I want the wall to be less than 2' high. So if I go out from my house 2' will that effect the ground freezing and/or damage to the foundation? I googled this for a while but can't find any info.
    i attached a pic because might be hard to imagine otherwise.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    The only possible issues I see are forcing water towards the foundation.
    As long as you provide for drainage there should not be any issues
    Michael
    Looks good, but you do realize that your picture does NOT show the footing 48" below the ground.
    Oct 2010
    sd
    I think you are making a joke about my drawing not being to scale so haha
    if you ment something else I don't know what you mean.
    Jan 2008
    What he is saying is that if your picture is supposed to be portraying the building footing at 48" depth, then the retaining wall footing should be drawn at the same depth as the building footing.
    Oct 2010
    sd
    why would the bottom of my retaining wall have to be to the same depth as my footing for my house? that would leave me with over half my wall in the ground.
    my concern of freezing is my houses foundation. I didn't if putting a wall near my house would mess with the frost line.
    Jan 2008
    The wall needs to have a footing, and if you want it to last, it needs to be below the frost line.
    Oct 2010
    sd
    i think i should have mentioned the proposed wall is going to be from interlocking blocks. sorry about that.
  1. Replies: 7
    Last Post: 03-10-2010, 12:44 PM
  2. Adjusting wall plates - Moving switches & receptacle outward so wall plate looks good
    By jamminjoe in forum Electrical Forum discussion & Blog
    Last Post: 12-29-2009, 06:21 AM
  3. Need Wall Hung In-wall-carrier for Toto
    By Breezer in forum Toilet Forum discussions
    Last Post: 08-25-2009, 01:55 PM
  4. Leaky Basket Strainer/Frozen retaining nut
    By Verdeboy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-20-2006, 08:58 PM
  5. Wall-mount Kimera on Geberit in-wall tank holder
    By RLman in forum Toilet Forum discussions
    Last Post: 04-26-2005, 10:53 AM
