Results 1 to 11 of 11
Thread: Does a water softer shorten the life of your water heater?
Hybrid View
    DIY Junior Member 13jerry's Avatar
    Mar 2011
    Florence, KY
    Default Does a water softer shorten the life of your water heater?
    does a water softer shorten the life of your water heater
    It is a prime example why you need
    a water softener in the mid west .....
    the fellow did not have a water softener , this heater was 10 years old
    and they had 7 people living in the home when it finally started leaking in the garage........
    usually you use about 300 per year to heat your water,
    my guess is he probably used 3 times that much to keep this pig heating water...
    he was still not interested in doing anything about it...
    the water softener would literally pay for itself in gas savings pretty quickly
    Master Plumber Mark
    DIY Junior Member ferd's Avatar
    Mar 2008
    Cool
    Have had a softner and the same water heater for the last 35 years. If anything, I would think that a softner would help a water heater.
    A water softener converts the "nonsoluble" calcium ions into sodium ions which are soluble so they do not build up in the water heater. This implies that a heater with soft water will outlast on without a softener.
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    I am considering a water softener because the water here is hard as concrete. What are the drawbacks? I have heard it can cause copper plumbing corrosion. ARE there any drawbacks?
    Jan 2012
    California
    Quote Originally Posted by big2bird View Post
    The pluses and minuses would take volumes to go over, but in general, the positives greatly outwiegh the negatives. Here is a quick read on the positives of softened water (true, not "anti-sclae, magic electronic wires, or magnets). http://wqa.org/pdf/pressreleases/battelleresults.pdf
    As to the hot water heater issue, as a licenesed boiler technician, we recommend turning off (bupassing) the softener for most water heaters, boiler, steam boilers (not counting steam boilers in excess of 400 PSI, superheated steam etc) for a few days once a year. This simply puts a mm thick layer of protective scale over the surfaces of the system including the sacrificial anode without affecting energy efficiency etc. Again, this is a long a tedious discussion, but in general... soft water good, hard water bad, and running hard water on a very rare occassion for short amounts of time will have little negative affect...
    I am not going to argue this point, just adding my 2 cents that for most systems, softening is beneficial so long as they are operated at high efficiency.
  1. hot water tank life span
    By rburt5 in forum Water Heater Forum, Tanks
    Last Post: 12-23-2009, 12:24 PM
  2. Water heater question - cold water, water leaking thru overflow pipe
    By jonyi in forum Plumbing Forum Discussion & Blog
    Last Post: 09-26-2009, 01:26 PM
  3. Hot Water Heater Life Span
    By smitty52 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-01-2009, 09:12 AM
  4. Water softer installation. Where?
    By chinino in forum Plumbing Forum Discussion & Blog
    Last Post: 03-16-2005, 02:48 PM
  5. Hot Water Heater Life Span
    By bendhamma in forum Plumbing Forum Discussion & Blog
    Last Post: 11-05-2004, 10:52 PM
